problem from battery disconnect
Old Jun 17, 2006 | 07:38 PM
bfunk850's Avatar
bfunk850
Cruising
Default problem from battery disconnect
I was installing a battery disconnect switch and imputs for easy charger connection. I had the charger connected to the terminals so I wouldn't loose power. BUT, it is really tight working around that neg. terminal and I must have lost power for an instant. https://www.corvetteforum.com/forums...illy_nilly.gif
The driver settings are no big deal, I can do that again, but some how the window in the door no longer does its little automatic 1/2" adjustment when I close the door.
Where do I start in getting this window dance to resume?
Old Jun 17, 2006 | 08:02 PM
Hoonose's Avatar
Hoonose
Reindex windows. Raise to top hold an extra 3 seconds. Same at bottom....
Old Jun 18, 2006 | 02:14 AM
bfunk850's Avatar
bfunk850
Cruising
bottom....
https://www.corvetteforum.com/forums...s/thumbsup.gif
Done! Easy, thanks
brian
To problem from battery disconnect
