Hints on improving 60-ft times?
Old Jun 17, 2006 | 11:17 PM
bunk22's Avatar
bunk22
Default Hints on improving 60-ft times?
Still frustrating for me. I've got probably 30+ passes in my car, on stock tires but have yet to get better than a 2.1X. Today was the first day I've run consistant 2.1's. My first two passes were in the 2.2 range when a GTO owner suggested I keep TC on while launching, then switch it off prior to switching. It actually helped with every run after that being in the 2.1 range. Tire pressure around 25 psi with a slight burnout, just to heat them up. Runs were:
8.471@88.200 (2.133)
8.470@87.823 (2.109)
8.508@88.361 (2.141)
8.535@88.448 (2.186)
DA ranged between 3500-3900' (increased as the day wore on) so not the best for times or mph. All times correct to low 8's@92.X at sea level. Any suggestions would be appreciated.
Old Jun 17, 2006 | 11:24 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Track preparation could have something to do with it.
Try running it at another track.
Old Jun 17, 2006 | 11:29 PM
bunk22's Avatar
bunk22
In due time, moving soon but this is the best local track (out of two). Sucks as well since it's at altitude and usually ***** hot this time of year.
Old Jun 18, 2006 | 08:21 AM
HITMAN99's Avatar
HITMAN99
Heat the tires up more, lower pressure to 22 lbs.
Old Jun 18, 2006 | 08:39 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Do a search for CF member Ranger, he's got links to tips in his signature, and read those and some of his other threads. There is a feel to holding the revs steady and walking out the clutch quickly, not dumping it, to get a good 60 ft. Ranger describes it very well and even has a video linked to one of his threads.
Reading Ranger's threads and watching his video and listening to the engine taught me how to launch - I went from 2.1's to 1.7's consistently on my C5. I haven't learned this C6 yet, only had it a month, but I got consistent 1.8's first time out. But this car has torque management in spades, when I shift gears it feels like the engine is shutting off even though TC is off. That causes my times to suffer.
You will never find anyone who is good running TC. It does not turn off fast enough and if it kicks in your run is cooked.
Old Jun 18, 2006 | 08:57 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Short of lowering the read gearing
Old Jun 18, 2006 | 06:23 PM
dennis50nj's Avatar
dennis50nj
22 lbs will slow down anything under 24 lbs will set low tire sensors off car will slow down
Old Jun 18, 2006 | 07:02 PM
Ranger's Avatar
Ranger
Links Joe_G referred to are in my sig below.
Practice, practice, practice.
Ranger
Old Jun 18, 2006 | 08:33 PM
glennhl's Avatar
glennhl
I've actually had my best 60 foots with 30 psi. I run 2.05's with 24 psi and 1.99's with 30 psi.
Old Jun 18, 2006 | 08:47 PM
DrivnXcitment's Avatar
DrivnXcitment
hey Bunky,
Were you up at Palmdale? They generally have a pretty poor track setup up there. Have you tried Irwindale yet? Its supposed to be much better up there. I don't know, I never got to run there. Take care and I am sure I'll see you once you get to P'cola.
Old Jun 18, 2006 | 08:51 PM
Ranger's Avatar
Ranger
There several variables to combine in seeking to improve your 60' and 330' with an M6/M12 tranny...
(1) Launch rpm
(2) Clutch release speed
(3) Throttle squeeze
(4) Rear tire pressure
(5) heat of the rears by burnout
(6) Impact of Torque Management
Measuring the impact of a rear psi change is valid if the other variable remain generally constant.
One reason to reduce the rear psi to 26-27 is to decrease the chance of breaking the right CV joint due to wheel hop on the 1-2 shift.
Generally the key variable is choosing the right launch rpm...the allows a bit of spin so that when the tires hook, the rpms explode upward without a bog.
Ranger
Old Jun 18, 2006 | 11:30 PM
bunk22's Avatar
bunk22
Originally Posted by DrivnXcitment
hey Bunky,
I'm running at Barona, the only local track. Otherwise I have to drive around 2 hours, just no time for that. I hear there is an 1/8th mile track near P-cola, at least near sea level no doubt.
Old Jun 18, 2006 | 11:32 PM
bunk22's Avatar
bunk22
(1) Launch rpm
Ranger
Good stuff and I've already marked your info in my favorites. I will study, go from there and practice, practice. Should have just done a search under your name.
Old Jun 19, 2006 | 08:51 PM
dennis50nj's Avatar
dennis50nj
t.m.
Old Jun 19, 2006 | 08:58 PM
dennis50nj's Avatar
dennis50nj
my best 1.764 a4
Old Jun 19, 2006 | 09:09 PM
CYA-Vett's Avatar
CYA-Vett
You need some spin or TM takes over...
Friday night my buddy borrowed my ET Streets. His first launch he launched at 3,500 and bogged. Since he could only get one more pass in he decided to go for broke (luckily he didn't break)...He launched off the rev limiter, the car hooked and bogged. Without some tire spin, your doomed....
Rear still in tact...
He was only able to pull a 2.1 off the rev limiter. Car was stock mn6 no tuning.
More proof for those that do not believe..........
Old Jun 19, 2006 | 09:24 PM
dennis50nj's Avatar
dennis50nj
TM. i always believed Dave
To Hints on improving 60-ft times?
Old Jun 19, 2006 | 10:35 PM
bunk22's Avatar
bunk22
I've always believed in TM. I thought the TM was removed with my tune. I did gain .2 and 4 mph after my tune but maybe it was more of an aggressive tune?
Old Jun 19, 2006 | 10:55 PM
glennhl's Avatar
glennhl
my best 1.764 a4
I'm not worthy, I'm not worthy. How the heck do you do it? Are you launching from idle? That seems to be my best procedure.
Old Jun 20, 2006 | 08:58 AM
dennis50nj's Avatar
dennis50nj
yes. and i don't floor it just like city driving. give it as much gas without spinning. roll into throttle after a few feet
