Considering the DTE Diff upgrade a few ?s
Old Jun 18, 2006 | 05:08 PM
CoolBlueC6's Avatar
CoolBlueC6
Default Considering the DTE Diff upgrade a few ?s
OK, I realize that the 05s have a little bit weaker rear diff than the upgraded 06+. Now, I am not going to be running huge HP/TQ. Right now, I am at 373.4 HP with bad DYNO conditions. With a few additional minor mods, I expect to be at around 390RWHP +/-, so the stage I is probably the route I will take. I do have a few questions and welcome any comments...
1. I have and really like my closer ratio base transmission. Going to 3.73, will I feel in the SOTP much difference, how much of a performance increase for auto-x and road course? Is 3.90 worth the loss in fuel economy/drivability...this isn't my daily driver, but I do drive a lot when the weather is good.
2. How much more reliability is to be expected?
3. With a reputable shop, approximately how many labor hours or total $ should I expect?
Thanks in advance!!
Old Jun 18, 2006 | 07:46 PM
CYA-Vett's Avatar
CYA-Vett
Thanks in advance!!
You want to go 3.90 or 4.10, not 3.73
You will lose such a slight amout of fuel economy that it should not even factor into your decision.
$300 to swap the rear, $900 for the gear install. $1,200 total. Throw in a hardened output shaft for $300, if you do it now the install is free while the rear is apart.
Old Jun 18, 2006 | 09:53 PM
CoolBlueC6's Avatar
CoolBlueC6
LG sells the DTE rebuilds with your choice of gear ratios. So, you are saying $300 bucks is about what I should expect for the swap. The gear install is already part of the rebuild. You have to step up to stage II for the hardened output shaft. Here is the link on the various packages: http://www.lgmotorsports.com/catalog...oducts_id=1550
Keep in mind, I will be on the road course and want to maintain some top end. So, what should I expect from a 3.90 ratio?
Old Jun 21, 2006 | 08:00 PM
CoolBlueC6's Avatar
CoolBlueC6
Anyone else have any input??
thx...
Old Jun 21, 2006 | 09:16 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
3:90 gears were one of the best mods in my C5. I loved them on the street, drag strip, and road course. Felt like the car lost 500 lbs - the SOP difference was amazing, like a different car.
That's why I'm getting a set installed in my C6 next week!
Old Jun 22, 2006 | 11:31 AM
ShockerRacing's Avatar
ShockerRacing
So the rear end swap is a pretty simple change? It seems like it should not be all that hard, or costly if you are buying the DTE Rear end.
Old Jun 22, 2006 | 02:07 PM
Stage7's Avatar
Stage7
What were the original gears?
Old Jun 22, 2006 | 02:58 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
3:42
I've done a clutch swap and torque tube rebuild with a buddy, if you have a lift and a transmission jack it's actually pretty darn easy to get the tube out and swap out the rear end. The vette is one of the easier cars I've worked on, you can get to most of the stuff pretty easily. We had a master mechanic give us a few tips and pointers along the way but it's not a bad job, nor should it be that expensive. I'd say 5-6 hours labor, 8 if they are taking their time. A good mechanic can do it before lunch, no question about it.
There's how to's on the forum for diff swaps including installing hardened shafts. Leave a ring and pinion swap to the professionals.
Old Jun 22, 2006 | 08:11 PM
CoolBlueC6's Avatar
CoolBlueC6
I am considering the purchase of a lift for just this type of stuff plus oil/tranny/and diff fluid changes. Oh yea, so my wife can park in the garage:o She can park underneath. My clearance is just about at the minimum.
Anyway, that time fram gives me a good idea as far as the shop that I use. He is awsome and his shop rate is $65.00 per hour. I'd much rather do it my self though, just for the hands on aspect. I have some track days planned for July and August and the extra grunt would be fun.
To Considering the DTE Diff upgrade a few ?s
