High squeak at start up??
Old Jun 19, 2006 | 03:00 PM
BB C6's Avatar
BB C6
Default High squeak at start up??
Guys, I put a set of Kooks headers, x-pipe and Corsa back half on my car and on start ups and rev's (at stand still) I hear a high pitch squeak??? Any suggestions??
Old Jun 19, 2006 | 03:43 PM
LS6dude's Avatar
LS6dude
sounds like a loose belt.
Old Jun 19, 2006 | 04:06 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Put a wrench on the bolts & tighten.
Either that or your neighbor's cat is sleeping under your car
Old Jun 3, 2010 | 11:57 PM
97TorchRedCoupe's Avatar
97TorchRedCoupe
Default High pitch squeak too
I have a high pitch intermittent squeak too. Can't seem to isolate it. I changed the alternator thinking it was the bearing but still have the problem I lubricated the idle and tention pullies and was told the surpentine belt is new. Go figure. Anyone else have this problem?
Old Jun 4, 2010 | 07:58 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
You can't tighten the tensioners- they are automatic. Also, lubing the tensioner bearings is useless- they are sealed.
Check ypu harmonic balancer for wobble.
Old Jun 4, 2010 | 08:15 AM
97TorchRedCoupe
My research on the Forum validates your recommendation to check the harmonic balancer for wobble. I checked it and it wobbles a little. Nothing out of the ordinary but can cause the squeal. In the "old days" we used a bar of soap on the belt to quiet things down. A new harmonic balancer is a costly replacement and "do it yourself' requires about 4 hours of intensive labor. Oh well. The saga continues.
Thanks for the comeback.
Regards,
Mark
To High squeak at start up??
