Gas Guage Issues
Old Jun 20, 2006 | 09:39 AM
LOS ANGELES PI's Avatar
LOS ANGELES PI
Default Gas Guage Issues
Anyne reporting problems? I top off and it only shows half full and the computer states same, ie; distance to empty.
2006 MN6 Z51. I would like to fix this myself if I can, I hate taking my baby to the dealer.
Any ideas? Anyone with same issue and know the part number? I think it may be the sending unit at the rear driver tank.........
Old Jun 20, 2006 | 10:42 AM
DANNOV's Avatar
DANNOV
Do not top off your tank. Stop filling when the pump shuts down, don't add a drop more of gas. If you overfill you get these strange problems, we have had many posts here about this problem.
I experienced a similar problem and it was cured by just being very careful not to overfill the tank.
Old Jun 20, 2006 | 10:45 AM
dbradley's Avatar
dbradley
Try some Chevron Techron additive before you take anything apart. Newer gas formulations cause the senders to get some sort of coating on them and cause similar condition. The "Top Tier" fuels have additive to prevent this. Most auto companies recommend the Techron as a cure. I had the same issue with my S-Type and this cured it. From then on, Chevron gas for me.
Old Jun 20, 2006 | 12:33 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I have the same problem sometimes. What I learned to do was jerk the steering wheel left and right quickly. The needle comes back to full and stays there. Problem solved.
Old Jun 20, 2006 | 01:02 PM
Big Ron 77's Avatar
Big Ron 77
There are a couple of things, although yours sounds like the sending unit. There is also a software patch for eradic fuel readings, as in the gauge will go to empty, then bounce up, etc. That's my issue, and it requires a GM software patch.
As for the fuel sending unit, you can get one from one of the forum dealers, or you can find the part and part # here...
http://www.trademotion.com/partlocat...05&catalogid=1
Old Jun 20, 2006 | 03:56 PM
VET4LES's Avatar
VET4LES
I have read a couple of times where members have had the same problem and it turned out to be a kink in the transfer lines between the two tanks. If none of the other remedies work it sound like a trip to the dealer will be necessary. The local dealer did a good job on my fuel gauge problem.
Old Jun 20, 2006 | 04:48 PM
Hoonose's Avatar
Hoonose
Whoa! I thought it was just the opposite, to not drain your tanks to zero. I don't know about your car, but mine will take essentially no more gas after it automatically shuts off.
Hoonose's Avatar
Hoonose
This cured my 2002 Suburban!
Old Jun 20, 2006 | 06:25 PM
LOS ANGELES PI
Thank you all for posting, Ill take a look underneath and see what I see.
By far, the best was the following. I will have alot of fun driving down the freeway jerking the car from side to side, then when I get pulled over, Ill just say "Hey, I was just trying to unstick the float gauge in my new 55,000 sports car !!!!!!!!!!!!!!
DANNOV's Avatar
DANNOV
There are a ton of postings about this problem as well as a TSB, just don't overfill the tank. That little bit more gas after the pump shuts down creates the problem. Pump shuts down, don't add a drop more!
Old Jun 20, 2006 | 09:09 PM
DrivnXcitment's Avatar
DrivnXcitment
Yes overfilling the tank is kind of the problem. You should be able to FILL the tank without any issues on any car. What happens on our cars is the fuel level sensor overtravels its path. When it does, it sends a false signal to the computer and for some reason it registers at zero fuel, or a fuel system problem. The software upload as mentioned earlier, reflashes the ECM and delays the signal that tells the computer the fuel sensor has overtraveled its path.
First take your car to the dealer and have them do the software update. If that does not work, then it could be the left tank fuel sending card. That has been known to go bad in many cars. In order to replace the card, they have to drop the fuel tank. It is a 3-5 day job. The software update is about a half an hour job.
Like stated earlier, there is a TSB out about this problem. Do a search for "Service Fuel System" and you will find all the answers you need on this. Hope this helps.
P.S. By the way I am taking mine in tomorrow for the software update, I have the same damn problem.
Old Jun 21, 2006 | 12:42 AM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
LOS ANGELES PI,
If you want, you can bring it by and we can update your C6 with the latest calibration from GM and see if that takes care of your issue. We are tied into GM's TIS 2000 database system and can update all GM vehicles in about 15 minutes. This way it can be done while you wait and you won't have to go to the dealer.
Let me know.
Thanks!
Shawn
Old Jun 21, 2006 | 02:10 PM
BIG Dave's Avatar
BIG Dave
I had this problem with my 2002 C5. I always used Sunoco gas and always topped off. Since I bought my C6, I changed to Shell gas and never top off. Never found out for sure if it was the gas or topping off or both. Haven't had the problem yet and have nearly 17K miles on her...
Old Jun 21, 2006 | 06:49 PM
DSchaefe's Avatar
DSchaefe
Why can't GM fix this annoying crap? I had the same problem on my C5, I just assumed they would have addressed this on the C6. What a joke.
Old Jun 21, 2006 | 08:48 PM
DANNOV's Avatar
DANNOV
You are 100% correct. I will bet that the tops will be flying off the 2007 Corvettes too! There is no reason for continuing problems that should have been fixed long ago.
Old Jun 23, 2006 | 06:51 PM
SFHC6's Avatar
SFHC6
w/Drvn Exctment... I had the same problem. As mentioned earlier, it is a fuel card issue. My engine light eventually went on, as well as an erratic fuel gauge.
I had mine to the dealer a couple weeks ago for the re-program. It only took about an hour and I have not had an issue since... knock on wood!
The tech also stressed that the fuel tank should never be topped off... stop at the first time it clicks off. Although, it can happen without topping off. Good luck!
Old Jun 23, 2006 | 10:51 PM
TrackNoob's Avatar
TrackNoob
Respectfully, I think your advice is incorrect.
I have +13K miles on mine, and I consistently both consume the fuel to below well the 'low fuel' DIC warning, as well as then carefully filling up WITH A TOP OFF of at least one click or two after the fuel pump auto shuts itself off. Never had a spillage, but have had one or two dribbles into the overflow tube. Easily handled.
Could you give any examples, or any theory, as to why fully filling the tank as it is designed to be, causes these 'strange' or mysterious issues?
It is indeed a fact that many early fuel sending units had defective sensors, but if that is the case, I would think you would want to know that, and have it properly repaired rather than crossing your fingers and only running between 1/4 and 3/4 of a tank. That does not appeal to me one bit.
To Gas Guage Issues
Old Jun 25, 2006 | 12:18 AM
JaminJ's Avatar
JaminJ
Had the same problem with my 03 Tahoe and 00 Vette. Gauges would not funtion acurately or act bizarre.
Chevron Textron additive (Costco 4/$10) resolved issue with not filling up all the way, first shut off @ pump. And used 1st tier fuel not the am/pm junk.
No issues with the 06 Vette just use Chevron and will use Textron additive once in a while.
Old Jun 25, 2006 | 09:51 AM
Mark S.'s Avatar
Mark S.
Why top it off?..as soon as you get close to knowing your almost full...stop...I think the topping off too much is causing the problem. Besides...fuel is heavy and that slows you down a bit...
Old Jun 25, 2006 | 10:04 AM
SFHC6's Avatar
SFHC6
This issue was typical for early 2005 models... it is not a defective sending unit. It deals specifically with the "fuel card". When the fuel gets above a certain level... it was sending incorrective information to the computer, causing the issues with the gas gauge.
GM put the new programming into place on the '06 and newer models, which supposedly delays that message... that is why you do not experience any problems filling your tank.
And when I say it is not recommended to top off... you just stop when it hits the first click... most new cars have the same recommendations... not just vettes!
