Old dog needs new trick help
O'Reilly Auto Parts has a tool to rent, but it looks to be less than a foot long, and I can't visualize how to fit the jaws on the top and bottom of the shock. I have considered using large cable ties to keep the shock compressed, but not looking to invent any new wheels if there is an accepted method to do this.
All help is greatly appreciated!
Thanks in advance.
Thanks in advance.
Thanks! Done and out.
Now, how do I torque the nut on the piston shaft while holding the piston shaft in place with the torx?
I really am mising the '60s! If only I could remember where I left them.
Once you have the nut tight, the shaft should not turn. You can probably use a deep socket to torque the nut once you are sure the shaft isn't turning without being held by the torx. Or, another approach I have used for 4X4 wheel bearing nuts would be the following: Got a spring operated fishing scale? Measure your closed end wrench (center of one end to center of the other end) with a ruler, and divide by 12 to convert to feet. Then divide 19 ft-lb (recommended torque for front shock top nut) by the length of the wrench in feet to determine the force to be applied to the other end of the wrench to give you 19 ft-lb. Hook the fishing scale to the wrench end and apply force to wrench perpendicularly until you reach the calculated force on the fishing scale.
Example: Say your closed end wrench measures 6 inches...dividing by 12, it's 0.5 foot. When you divide 19 ft-lb by 0.5 ft, you find you will have to apply 38 pounds to a six inch wrench to get 19 ft-lb torque.
If you like, you can double-check this torque with a torque wrench/deep socket once the nut is tight enough that the shaft doesn't turn. This is the preferred method...38 pounds on a six inch wrench will be pretty unstable; might get your knuckles busted big time.
