My question to any one out there, have recently ordered and received brand new c6 corvette. Car was given proper 500 mile break in then driven to 960 miles then sent off to have procharger D1sc installed -heads & cam package-methanol-injection & so on. Has anyone else out there done this methanol injection kit and if so where can i purchase methanol!!!!!! I live in Albuquerque nm. Work was done at world famous MTI based in Houston TX----I must say most professional shop i ever visited & most knowledgeable- All the way from David Coates to Jason Cohen. Dyno #'s were extremely positive--------rwhp-639.2----rwtq-530.8!!!!!! So if any one could please help with locating methanol in Albuquerque NM. Would be greatly Appreciated!!!!!!!! Thank you Joseph Cordova. :
Check the local chemical supply companies....Rhinchem (Sp) is a starter...with Intel in town , someone must have it......Pat
If I'm not mistaken, a lot of the methenol injection systems use a water/methenol mix. Common over the counter windshield washing fluid is what is recommended for use. Snow makes a highly regarded water injection system and that is what they use.
I did the Snow Performance kit and it was very ez to install.
You can get the meth from Homedepo.
I use the Snow Performance "Boost Juice"
Perfect blend all the time
The best for real Methanol and not denatured alcohol (which does work fine btw) is your local hobby shop that sells Radio controlled Planes, Cars, Helos...Otherwise Denatured alcohol can be foud at Home Depot, Lowes, Wallmart... The best kit IMO is the East Coast Supercharging (ECS) meth injection kit.
Jeremy
Distilled water and Isopropyl alcohol. Thats what I used in the only water injection I have used. Windshield washer fluid is a poor choice, there are no standards on the quality of the water or the percentage of alcohol. Most of the spray nozzles in an injection system have very small openings and junk fluid can clog them. Be sure there is a filter between the tank and spray nozzle
