Z51 Option
everyone that got the z51 likes it.....those that didnt get it dont like it...just like the last 10 times this question popped up.
The Z51 has better tires and awesome gearing in the first 3 gears making the car faster with the same driver...(gotta cover that last statement for the **** jerk-off that always points out a non z51 with a good driver is faster than a z51 with a bad one.)
And yes pretty looking holes in the rotors making the ricers jealous.
Hey: the resale value will be higher for the z51 car since everyone wants the 'better suspension' so its a wash in the end.
After driving all three suspension options, it was obvious to me that the standard suspension would be the easiest and cheapest to modify to give the handling characteristics I wanted. A set of Z51 sways and Bilstein shocks made it just what I wanted, compliant and controlled.
The standard GS tires are wearing well. At nearly 30,000 miles, they still have about half their tread left. They do better in the cold and wet than the SC tires too.
The only track use my car sees is the ocasional foray at the drag strip. Bracket racing is all about consistency, and the A4 is a proven drag race tranny, so that's what I got, along with the stand alone 3.15 rear ratio option. There's a large knowledge base for tuning and modifying the A4, so it is easy to set it up exactly the way you want it.
On the street, my last car was a MN6, and I was frankly delighted to go auto with this car. The broad flat torque curve of the LS2 complements the A4 very well. More gears are neither wanted nor needed. (Note that the A6 may also prove to be a good tranny. You can just ignore the two overdrives for performance driving, leaving you with a decent 4 speed, albeit with ratios that are a bit wider than ideal.)
The other bits and pieces of the Z51 package, the bling drilled squeaky brakes, and the various extra coolers, didn't hold much appeal for me. The coolers might be useful for those who run extended road course races, but are just extra weight for a drag racer, and are unnecessary on the street. The drilled rotor brakes frankly have no redeeming virtues. If you drift over to the road race section, you'll find most of the serious racers either swap in solid rotors for durability and economy, or go with aftermarket big brake packages.
The only place where the Z51 package makes sense to me is if you compete in a SCCA pure stock class. Then it gives you a small edge. But for any sort of competition where aftermarket modifications are allowed, save your money for parts that can make a bigger difference in performance.
Mr Dog - I'm not with you on this. I'm at 24k mi w/Z51 and still 10k left on the tires. @ 5'10" @ 250+, the ride is fine for me. I came out of a Lincoln Mk8 and the Bride has an Acura RL 3.5. I love the road feel & control it provides. Daily driver 4 me too. As with all, it's a personal decision - gearing & oil cooler were the big selling point for me.
Goodyear Eagle 1 SC asymetricals:
* better dry grip
* worse wet grip, more expensive to replace
Oil cooler:
* more thermal capacity
* car runs colder longer during warm up, more costly to change oil, leaves dirty oil behind at change
Crosss drilled rotors & Z51 pads:
* 9% more swept area
* cracks, low OEM replacements, noisy, limit wheel choices, excess dust
etc, etc, etc,
But then I figured "Why bother" If you want it, buy it, if you don't don't.
But one thing I did want to share was the gear ratios, because there was a bit of slick marketing in GM's press information that was distributed at release. They claimed the Z-51 performance ratios made the car accelerate quicker. And let's give it that, I don't care to argue if it is 'real' or just theoretical.
But in the same articles it was claiming blah blah fifth gear blah blah 'better fuel milage'. Now wait a minute! I was going to list 'worse fuel mileage' as a negative on my little chart, but this seemed to refute that. How could that be?
Well here are the ratios, with a chart below.
Those sleasy marketers took the fact that the fifth gear is barely barely numerically lower for the Z51 than the coupe for that gear only and used that out of context to claim better fuel milage. Sheesh. If you look at the OTHER five ratios (including sixth) you see the reality. What makes thes scuzzy people do this?
RPO
Z06/coupe Z51
Final drive ratio 3.42 3.42
First gear 2.66 2.97
Second gear 1.78 2.07
Third gear 1.3 1.43
Fourth gear 1 1
Fifth gear 0.74 0.71
Sixth gear 0.5 0.57
Reverse 2.9 3.28
(Blue line is coupe, purple line is Z51)
My test vehicle was equipped with the Z51 performance package. In addition to larger brake rotors, performance tires, and a sport tuned suspension, the six-speed manual transmission had an aggressive gear ratio to improve acceleration. Also, it had a numerically lower fifth gear that gave the C6 Z51 better fuel efficiency.
Typical article, but found in many similar press pieces:
http://www.blackpressusa.com/news/Ar...ts&NewsID=3708
Wrong . [edited to remove my OWN error]
If you have the 2005 model and have the 3.15 performance differential, then am I correct in saying that your car is the same as a Z51 optioned C6 but without the suspension components, tires, coolers and drilled rotors?
and
and whatever. Please for the love of God just drive your f*cking Vette and shut up. That includes me too.
I was completely with you until you posted top speeed is in 6th. Top Speed is achieved in 5th gear. If you redlined 6th gear you would be going over 300 mph with either trans. Z51 is a great option package, you should really drive all three versions of the suspension and decide which one you like best. The quality of roads and your driving style/intended use are the biggest factors in picking your option package.
http://orig.app.com/jerseyautos/stor...045661,00.html
Wrong and wrong. Top speed is obtained in sixth gear on these cars.
I like the feel of the road. But, everyone has different tastes for everyday street driving.
http://www.roadandtrack.com/idealbb/...ageNo=2&num=20
I'll add to this post as I find more info.....
[edited to add]
I can easily accept that higest speed is obtained in fifth. No problem there, I mean that sixth overdrive is 0.50! But, sorry, but my
. The car still handles like a dream and stops on a dime w/out the z51 pkg.IMHO,
Gene
