rear-view mirror question
Old Jul 5, 2006 | 06:39 PM
Big D's's Avatar
Big D's
Default rear-view mirror question
I have a 2005 and I am putting on a radar detector which I had to take off the rearview mirror, any easy way to put the mirror back on. any info would help
Old Jul 5, 2006 | 07:17 PM
timd38's Avatar
timd38
It has a cam that locks it in. Set the mirror at 1/4 turn and turn it. If the bracket is broken off of the windshield, than you will need to glue it back on.
Old Jul 5, 2006 | 07:47 PM
TrackNoob's Avatar
TrackNoob
If it has a compass, you need to send it DIRECTLY to me for repair, and when I return it the compass will be gone, it will have an air bag light, but I will have typed up instructions telling you to turn it 90 degrees to work the cam action in order to replace it... :
Old Jul 5, 2006 | 10:01 PM
Big D's's Avatar
Big D's
well i know about putting the cam on a 90 degree angle, when doing so and lining it up it does not stay snug. It is loose even when stretching the pins out on the cam. any suggestions before it is off to the dealership, which I dread going to.
Old Jul 5, 2006 | 10:22 PM
TrackNoob's Avatar
TrackNoob
Sorry to be a funny guy when you still don't have a fix --I thought it was easy, but have never messed with my own yet. Going to go take it off right now, though, so that I can speak from experience. Seriously. Be back in a few.
Old Jul 5, 2006 | 10:30 PM
TrackNoob's Avatar
TrackNoob
120 degree turn
easy on/easy off for mine.
If yours is not staying snug, look at the mirror body -- see that it has some torx retaining screws and springs... might want to see what is up with that...
Old Jul 5, 2006 | 10:33 PM
TrackNoob's Avatar
TrackNoob
Hey, I forgot to dust under there with my diaper!
Jus lookit the crud built up under there! No concourse points for moi to enjoy with my Grey Poupon
Now [rubbing hands together expectantly] ... back to my certified 2005-compass mirror exchange program....
Old Jul 5, 2006 | 11:00 PM
Big D's's Avatar
Big D's
Looks like my mirror, but is not easy on. It seems like it is not catching. It goes on, but is loose if you wiggle the mirror. thanks for info.
Old Jul 5, 2006 | 11:12 PM
TrackNoob's Avatar
TrackNoob
If it is broken anyway, might as well pop the three torx and take a look...
OR just take it to dealer...
Old Jul 5, 2006 | 11:37 PM
Big D's's Avatar
Big D's
tomorrow i will call the service department and have them order a new cam for the rearview mirror and hopefully that will do the trick and also the 3 pins that sit in the cam will be ordered to
Old Jul 6, 2006 | 12:17 AM
aaaaa's Avatar
aaaaa
I recently had the same problem. The mirror was loose so I bent the springs and couldn't get the mirror back on. I straightened them leaving just a small bend and the mirror went on but it was loose. After playing with it for 30 minutes I turned the mirror just slightly and it firmed up. It's OK now but I'm afraid to adjust it for fear it will be loose again. Let us know what you find out.
Old Jul 26, 2006 | 02:13 AM
aaaaa's Avatar
aaaaa
bump
Old Jul 26, 2006 | 02:38 AM
CessnaDriver's Avatar
CessnaDriver
I dont suppose anyone knows which one of them thar wires powers the friggin airbag on off lights?
If you dont have kids, is there any reason to know wether its on or off?
If theres a problem, wont the warning lights on the dash tell you?
Ugh.
To rear-view mirror question
