Z51 mod from base??
Old Jul 6, 2006 | 12:25 PM
macguyver's Avatar
macguyver
Default Z51 mod from base??
Has anyone out there who has a C6 base suspension , went and changed to the larger crossdrilled rotors and/or calipers???
Old Jul 6, 2006 | 12:28 PM
timd38's Avatar
timd38
My car came with the Z51, but if changing to the Z51 rotors is easy. You need to change the caliper brackets and of course the rotors.
Old Jul 6, 2006 | 02:07 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
Calipers are the same
Old Jul 6, 2006 | 02:53 PM
AFVETTE's Avatar
AFVETTE
Carrier bracket is different to accomodate the larger rotors and the pads are different too. These are similar to what was used on the C5 Z06. They dust like hell but are very effective especially for track use.
Tom
Old Jul 6, 2006 | 11:46 PM
HalM's Avatar
HalM
I did it after running at Laguna Seca, CA (a brake heavy track)...Fichtner Chevy (one of the forum vendors) initially sent me a set of front rotors and front caliper brackets and we tested with just the bigger fronts and the car was vastly improved...we later ordered the rear set to complete the setup...
Old Jul 7, 2006 | 12:07 AM
CBB's Avatar
CBB
Say that again for all the people who think that the Z51 brakes are simply "bling".
Old Jul 7, 2006 | 02:52 AM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
It has been posted her many times that the Z51 rear caliper pistons are a different size than the base rear caliper pistons. I believe member Corvette Pilot has firsthand knowledge of the differences in the rear caliper piston. But, Yes you can put on the Z51 rotors/caliper brackets using the base calipers without issue.
Old Jul 8, 2006 | 05:59 AM
macguyver's Avatar
macguyver
Default x
How many out there have actually made the swap???
Old Jul 8, 2006 | 09:52 PM
macguyver's Avatar
macguyver
Default x
ttt
To Z51 mod from base??
