Ok Took My Car in For The Rearend additive..And Got The Car BAck with a CHECK ENGINE LIGHT..Never HAd this problem before..I Scanned it with my Predator and P0420 Catalystic System Efficience Below Threshold Bank 1 Came Up?? How do i get rid of this? Can someone Help me please..
On a C5 you can reset it from the DIC. On a C6, you have to have it reset by a tuner or the dealer. I suspect you also be able to reset it by disconnecting the battery, but I really don't know for sure.
Make sure your real O2 sensor wasn't disconnected when you had the car serviced. If so, make them reset the code.
well they said they tighten up my exhuast i had a few loose bolts on headers...and they told me they couldnt get the code out..so? can i do it with the predator? after i read the code. I tried to clear it and it didnt do it..So anyone else have an idea?
i have the same code on my dynatech headers. One time is just disappear for awhile..but then it came back. I can clear it with code scanner...but then it would reappear.
I got your PM and just sent you one back.
But, my Predator manual says 0420 is a COT enable temp code. When the Cats heat up too much, fuel will be added to cool the exhaust gas stream down.
You can adjust your COT enable temp with your Predator. The manual says only disable this if you don't have Cats. If you want to disable the code from setting, the manual says set your COT enable temp to a high 1200 degrees.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by YellowVette22
thanks jeff..hows the supercharger?
Should be arriving at Roger's this week or next. Scheduled install is for 7/19-20 and tune/dyno on 7/21. Then Jeremy will take it to Moroso on 8/5. The wait is killing me.
YellowVette22 was right, 420 is an efficiency code.
P0420 Catalyst System Low Efficiency Bank 1
P0430 Catalyst System Low Efficiency Bank 2
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Mine does the same damn thing. Clear the code, 300 miles later, CEL. Same code, same story. This is starting to p*ss me off big time.
Sure, shut off the CEL. Then what happens if there is a major engine malfunction ?
I had codes on my 01 Z28 after doing long tubes. Drove me crazy and I had the same concerns that you did. However the codes that show an engine problem, like misfire, are not disabled, so you will most likely catch any major engine problem. Plus, it's kind of like the old fashion way of finding the engine problem, you don't really need a code to tell you the engine is running terribly.
I had the codes turned off and never had an issue. You really only have a few choices. 1) Turn off the codes, 2) Jet Hot the headers and hope they hold the heat in better, 3) Live with the codes
NCM Lifetime Member
I have a better way to handle this. Remove the headers, the highflow intake and, the aftermarket catback. The car ran just fine when I took delivery. I truly wish I'd left it alone.
You don't need one, butt.....if you haven't had a custom tune after putting that stuff on, then that's what you could really use.
I've got a Honker, Kooks, hiflow cats, and a Predator tune - which is probably the minimalist way to go. I love the car with my mods, and I've had no problems with that setup. A real dyno tune by a good tuner using HP Tuners or LS2 Edit tuning software would be better.
Most of the custom tunes will disable the COT input so your Cats don't throw that 0420 code. You can do it with a Predator by setting the COT enable to a high 1200 degrees so it just isn't a factor.
I think that's the problem YellowVette22 had that prompted his initial post. He had a custom tune, but put the factory tune back in with his Predator before a visit to the dealer. As soon as he reinstalls his custom tune that disables the COT parameter, I'm sure he won't have any problems.
This is right from GM's service info.
this is on page 6-909
4 my ego, this has nothing to do with COT, so jet hotting your header will not help you with these two code. basicly what is happening is your post cat o2 is just as active as the precat o2. your ecm is thinking the cats are old and not able to convert HC, CO & NOx into something that is environment friendly. if you were running no cat but left the post o2 sensors in there, you would get the same code plus some more codes.
Don't get discouraged (easier said then done!). Once you get the codes removed you will forget you ever had a problem. After picking up 26 hp and 39 foot pounds of torque, I don't think I could go back to stock. Hang in there and just get a tune. You could even just get a mail order tune. Check with Jesse Bubb at http://www.wait4meperformance.com. He only charges $75 for a tune if you mail him your ECM.
The rear O2 sensors that cause the 420-430 codes ONLY monitor the cat performance to make sure they are still working (reducing emissions). It's the front O2's and other engine sensors that will potentially catch a major problem. So removing only the rear O2 functions can not mask any potential problems. You will be fine
