Magnaflow 14336 install
Old Jul 10, 2006 | 09:44 AM
bradb's Avatar
bradb
St. Jude Donor '06-'07
Default Magnaflow 14336 install
I did the Magnaflow 14336 install Saturday at Houston's Affordable Muffler. I also installed a pair of Magnaflow 35163 single tips.
Took them only 1.5 hours including replacing one exhaust stud at the front of the H pipe, Darn stock nut galled going back on and the stud snapped. Oh, well.
Affordable is one of those little shops that has all the correct tools (swager, mandrel bender, etc) and the work went smoothly. I like the look of the single 3" tips, makes more sense than dual tips to me.
There is a booming drone at 1700 rpm, but I'm getting used to it. Otherwise the car sounds like a small block V8 instead of a Lexus. I would suggest you not do this mod if you are on the fence about exhaust sounds. It is nicely aggressive under power and at idle. The drone will bother some people a LOT. It will be interesting to see if this changes as the muffler cure in over time.
Old Jul 10, 2006 | 03:25 PM
avalonandl's Avatar
avalonandl
An X pipe or H pipe should reduce the drone.
Avalon
Old Jul 10, 2006 | 03:28 PM
bradb's Avatar
bradb
Avalon
Thanks, but the stock pipes are H style already... or was I hallucinating? <hey, it can happen. I grew up in the 60s>
PapaTango's Avatar
PapaTango
Avalon
The stock exhaust system already has an H-Pipe built in.
Old Jul 10, 2006 | 03:33 PM
bradb's Avatar
bradb
Thanks, PT.
That was my memory from Saturday, too.
Glad to hear I didn't dream that!
Old Jul 10, 2006 | 03:36 PM
Fore58's Avatar
Fore58
Originally Posted by bradb
Thanks, PT.
MN6 or A4,A6?
Old Jul 10, 2006 | 03:38 PM
bradb's Avatar
bradb
Originally Posted by Fore58
MN6 or A4,A6?
It is a MN6.
Old Jul 10, 2006 | 04:20 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
The drone will mellow out quite a bit after about 2000 miles.
Old Jul 10, 2006 | 04:28 PM
bradb's Avatar
bradb
Hehe, yeah or I will get used to it... or a little of both. I tried turning up my Bose® AudioPilot® Soundstage®, but it sounds like crud turned up loud.
Just kidding, it actually isn't that bad to me... I was only warning off some people who might do this because it is a real drone.
Thanks for the info.
Old Jul 10, 2006 | 06:33 PM
PapaTango's Avatar
PapaTango
Mine mellowed out in just a couple of weeks of steady to work and back driving. I don't even notice any drone now, unless I get really low in the RPM range in 5th or 6th gear.
Old Jul 11, 2006 | 10:47 AM
bradb's Avatar
bradb
Default Pics added
I've added a couple of pics of my install. Yeah, I know the car is dirty, it had been raining every day here in town last week. <grin>
Old Jul 11, 2006 | 06:14 PM
wratran's Avatar
wratran
good choice...a lot of guys are buying the full system for $1000...which is basically the same mufflers. I had the same setup except dual tips.
The piping that came with the $1000 system are the same as stock
Old Jul 11, 2006 | 06:39 PM
rckt's Avatar
rckt
Do the flowmasters sound like the magnaflows? I rather spend $300 than 700.
Old Jul 11, 2006 | 07:06 PM
V Vette's Avatar
V Vette
Thanks for the honest write up!
Old Jul 11, 2006 | 08:33 PM
bradb's Avatar
bradb
Sure, might as well tell it like it is. I think for the money, it can't be beat.
Old Jul 11, 2006 | 09:16 PM
Wass's Avatar
Wass
St. Jude Donor '09-'11
You can buy MagnaFlow #14336 here for $87.03 each including shipping.
http://www.bestautopartsonline.com/SSOVAL.html
Old Jul 11, 2006 | 09:19 PM
wratran's Avatar
wratran
http://www.hottexhaust.com/detail.asp?PRODUCT_ID=14335
$17 cheaper per exhaust...the tips are cheap too
To Magnaflow 14336 install
Old Jul 11, 2006 | 09:36 PM
0corvette pilot
Former Vendor
I love the single tips, I think I may get that done on mine!
Old Jul 11, 2006 | 09:41 PM
bradb's Avatar
bradb
I used
http://www.performancepeddler.com
but, your source is slightly cheaper. Good find!
Old Jul 11, 2006 | 09:42 PM
bradb's Avatar
bradb
I really like the look.
I don't 'get' twin tips on a single pipe.
Doesn't make sense visually.
