light'em up?
Old Jul 13, 2006 | 08:49 PM
jbh2403's Avatar
jbh2403
Default light'em up?
What is the best way (most effective and least harm to the backend)to light up the rear tire before a track run. Have really 0 experience here so any help would be great
Old Jul 13, 2006 | 10:23 PM
98vettered's Avatar
98vettered
Active Streak: 90 Days
If you are just running with street tires ....I don't think lighting up your tires is going to be an issue. (Won't help)
Are you runnning a 6 sp manuel or auto?
If an auto just let the tranmission do all the shifting for you.
The manual transmission takes more skill getting the traction to the pavement.
One other thing. Put it in compititon mode. And hang on and enjoy the ride.
Old Jul 13, 2006 | 11:13 PM
HITMAN99's Avatar
HITMAN99
Put it in Competition mode. If you have an A6, put the gear selector in "S" (Sport), but don't touch the paddles. It will start in first gear, and shift by itself.
At the track, drive around the water box. In general, tracks prefer that only cars with slicks use the water box, as water will get trapped in the tire tread, throw water all over the fenderwells, which will then drip onto the track.
Wait until the starter gives you the high sign, then get on the throttle hard to spin the tires. Once they are spinning, you can use the brake to keep from going forward to fast. When they start to smoke, ease off the throttle, proceed up to the starting line. Creep up on the line until the first staging light goes on, then a tad more until both lights are on. Then you're ready to launch. The lights on the tree will count down, so leave on the final yellow light --- don't wait for the green.
Old Jul 14, 2006 | 05:03 AM
shopdog's Avatar
shopdog
Depress brake pedal hard, push linelock switch, release brake pedal, light'em up, let off, release linelock and proceed to stage.
If you don't know what a linelock is, it is an electric solenoid valve that goes in the front brake hydraulic circuit. After you pressurize the lines with the brake pedal, you push the linelock switch which closes the valve. Now the front brakes won't release until you release the linelock switch and open the valve. This holds the car in place while you spin the rear tires without having to fight the rear brakes, which would add a lot of stress to the rear.
Old Jul 14, 2006 | 12:13 PM
Waveblaster785's Avatar
Waveblaster785
Why Comp mode?? Hold the button down for 5 seconds and it will turn everything off. Except for torque management
Old Jul 14, 2006 | 11:12 PM
jbh2403's Avatar
jbh2403
Guess I should have stated that I have a manual tranny....the line lock seems like a great idea and would lessen the load on the rear instead of using the e brake. How much does something like that run plus install our of curiousity?
To light'em up?
