Hey guys this is my first post. I have a new 06 paddle shift. I would like to know what kind of numbers people have got on the track with their paddlers. Second is there a gear dif between z51 paddles and regualr paddles?
There is a thread out there on times. As far as gear difference between a Z51 and Non Z A6 there is none they both have the same rear end and there is only 1 A6 option.
My car has the quickest posted time for a stock A6 C6 so far, the average is around 12.7x or so I think.
As mentioned above there are no gear differences, be it in the trans or the rear differential, between Z51 and non Z51 automatics for 2006/2007.
Are you asking what are the times when comparing shift by paddle or by auto? I have run the paddles a few times at the track. Out of the 5 times I have done it I have only had 2 passes where I did not hit the rev limiter. And on both of those passes I think the 1-2 shift happened a little to fast. My times have always been just a little slower buy my trap speed a little faster. I think that is because I can get a couple of hundered rpm more out of the 2-3 gear shift on the paddles. But the 1st to 2nd gear shift happens so fast you really have to be on your toes so you don't hit the limiter. I have toyed with the idea of a shift light but really have know idea about how I would go about it. I think if you could make a perfect pass in paddle mode, at least until we are able to change the shift points this would yield the best time. But getting that perfect pass is the hard part.
Paddle mode might ultimately turn out to yield the best results but I also agree that for now:
Originally Posted by SHOOTER 49
S mode and paddles NOT engaged is the quickest way.
LS1, your 12:48 is awesome. Were you in auto "S" mode? What was your temp that day, altitude, etc?
Yes, it was in 'S' full auto mode, TC and AH off. Weather conditions were very good, it was cold out (March in NJ) which does often hurt traction as well. While I thought it was great air when I was there I later found out the DA was barely negative (roughly -300 or -400 I think) that day. Good air yes but I've raced in even better (and will again ) in other cars in the past as well.
I tried the paddles on a later visit (different track) and wasn't happy, hit the rev limiter and it was a total mess LOL.
I started to use the shift light more often on paddle shift. The rev limiter sucks when you hit it....it shuts down everything. The raptor shift light is very small. I mount it on the pillar.
What is your burn out method? Power breaking? Line Lock?
Power braking yes (the car is stock so no line lock, yet , I probably even did too much of a burnout for the car dead hooked every time, I think a little spin might've helped my times even more maybe.
Actually I've never had a line lock on my 11 second Z28 either, with an automatic it's quite easy and doesn't even hurt the rear brakes too much if you're smart about it.
May not hurt the brakes, but it is not good for the trans.
True, a line lockless burnout hurts the transmission AND the rear brakes to some extent as well if you want to get technical but even with a line lock the trans isn't exactly loving the burnouts either LOL.
