Live data from OBD
Old Jul 18, 2006 | 04:54 PM
Lowviz's Avatar
Lowviz
Cruising
Default Live data from OBD
Sorry if someone has answered this question already (as I did search), but what ways are there to pull live data out of the C6 and record it for later analysis and use?
I'm hoping there is a straightforward way to do this using the OBD sensors and a PC link, but all my searches so far have led me to products that either don't support LS2 engines or aren't really real-time solutions.
Thanks!
Old Jul 18, 2006 | 07:28 PM
C6dude's Avatar
C6dude
HP Tuners Pro is what I use. You can plug it in your car without your laptop hit the record button and go for a ride and capture 80 minutes of engine info in real time for later in your PC. I have a wideband 02 hooked up for an AFR log also. I'm sure there are other programs . Good luck
Old Jul 19, 2006 | 01:30 AM
Chipps's Avatar
Chipps
I think Digimoto and the Auterra unit will do this. I just ordered the Digimoto hardware and software, so I will soon see. If it doesn't do the job I will try Auterra software. I believe the hardware for either of these products also supports other software, such as the PCMScan software. http://www.digimoto.com/ http://www.auterraweb.com/
Old Aug 8, 2006 | 05:43 PM
crease-guard's Avatar
crease-guard
So could one use the Auterra hardware and interface with HPTuners software?
Jay
Old Aug 8, 2006 | 06:54 PM
boosted_z06's Avatar
boosted_z06
Ease is the only laptop scanner that does the full speed CAN and GMLAN, supports all the new parameters GM added, does bi-directional to modules and supports several GM relearn functons
I use it on my 2006 Z06 and works really good.
Thanks!
Old Aug 9, 2006 | 02:17 AM
crease-guard
This sounds like exactly what I'm looking for. I want to put in a car computer in the double din slot. I want to control all multi-media from that, GPS, cameras, maybe even other interfaces with laser jammer and Valentine.
But one of the things I'd really like to do is to be able to do real time scanning and tuning right there from the drivers seat at any time. I can have all the .bin files right there, no need to hook up a laptop. Plus, with Auterra, they have the dyno part of the software. I know it's not terrible accurate, but the cool factor is too good to pass up.
I'll google Ease, but you have a site for it?
Jay
To Live data from OBD
