Disable CAGS
Old Jul 20, 2006 | 04:55 PM
CAJUN C4's Avatar
CAJUN C4
Default Disable CAGS
Best palce to do away with the 2nd to 3rd CAGS.At the Trans or the relay?
Old Jul 20, 2006 | 05:29 PM
BEZ06's Avatar
BEZ06
Transmission.
Actually, it's a 1st to 4th CAGS (Computer Assisted Gear Selection). Maybe that's what you meant - it skips 2nd and 3rd.
Pick a forum vendor and buy a CAGS eliminator for $15 to $20. Plugs right into the solenoid on the transmission.
This picture is from the Corvette Garage site:
Or, you can disable it with tuning software from a Predator to LS2 Edit.
Also, I think in the FAQ's there's a link to a discussion about buying a resistor at Radio Shack for 5 cents if you want a real cheap DIY job.
Bob
Old Jul 20, 2006 | 07:00 PM
MYVetteBy25's Avatar
MYVetteBy25
Can anyone point me to someplace I can buy an eliminator that does not require any zip tie? Most eliminators I've found only plug into the harness and require it to be zip tied to the transmission. I know there are some in which you can plug one end into the harness and the other into the transmission, thereby eliminating the need for zip tie. Who sells these? I have a simple resistor in there now, but am looking for a more permanent solution.
Old Jul 20, 2006 | 07:11 PM
Colovette's Avatar
Colovette
SLP Performance Products, Ecklers, Zip, Mid America and probably several others have a CAGS adapter that connects the wiring harness to the solenoid.
BEZ06's Avatar
BEZ06
I dunno what's the problem with using a zip tie to hold it up out of the way - that's what I did with my install a year-and-a-half ago and it hasn't given any problems.
Take a look at this CAGS eliminator from forum vendor Zip-products. It looks like it might be one solid unit. It's still gonna add a couple inches in length to the wiring harness to the solenoid and it still might be best to zip tie the slack in the harness up out of the way.
Zip-Products CAGS Eliminator
Bob
To Disable CAGS
