C6 Charging System Error
Old Jul 21, 2006 | 10:28 AM
MikeyCarz's Avatar
MikeyCarz
2nd Gear
Default C6 Charging System Error
Heres a problem that might eventually be one all C6 owners will have. First is there anyone out there that has had the charging light come, or had an error code regarding the charging system? If you have had an error (with the exception of a bad alternator) what was the root cause and how was it fixed or are you still having an error and unable to determine the cause, if this is the case what are the symptoms. I am presently working with GM now to find the inconsistancy of this problem.
