CHANGING SHIFTERS (undocumented)
Old Jul 21, 2006 | 10:36 PM
kelp's Avatar
kelp
Default CHANGING SHIFTERS (undocumented)
This is an undocumented fact not found in the C6 service manual, section 7. Supplement this to your documentation when changing your shifter:
Place the shifter in neutral. Press down the shift control neutral lock pin until it engages the transmission control rod. Test the shifter. The shift lever should not move. Remove the shifter. It may be necessary to remove the shift control neutral lock pin during this process. Regardless, remove it and reinsert it at a 180 degree rotation. Again depress the shift control neutral lock pin until the transmission control rod is immobilized.
Change shifters as instructed. Do not insert the upper short portion of the shift control neutral lock pin into the groove of the shifter. The shifter does not move because of 4 bolts. The transmission control rod is immobilized by the shift control neutral lock pin. Secure the bolts of the new shifter.
Remove the shift control neutral lock pin and store it in a safe place.
If the shift control neutral lock pin remains installed, even if attached properly to the shifter, it risks slipping down and locking the transmission control rod in a rearward direction. This results in the gear being locked in 1st, 3rd or 5th.
Old Jul 22, 2006 | 07:42 AM
Miaugi's Avatar
Miaugi
I guess you know this first hand huh? This is why your car got stuck in the driveway I assume?
Old Jul 22, 2006 | 08:56 AM
VET4LES's Avatar
VET4LES
Good information, thanks.
Old Jul 22, 2006 | 09:47 AM
Jagcvette's Avatar
Jagcvette
Interesting but when I changed my shifter to a Callaway short throw I did'nt do any of the above and have had no problems.
Old Jul 22, 2006 | 10:03 AM
kelp's Avatar
kelp
You have to say "Do you feel lucky?". This won't happen to most people. You may never have a problem with it.
Old Jul 22, 2006 | 01:53 PM
jsk96z28's Avatar
jsk96z28
you have any pictures, what is this nuetral lock pin?
Old Jul 24, 2006 | 06:28 PM
timd38's Avatar
timd38
Thanks!
Old Jul 25, 2006 | 01:30 AM
LOS ANGELES PI's Avatar
LOS ANGELES PI
It look slike a bent allen wrench, in the I slot in the forward portion of the shifter assembly.
Aftermarkets use a thicker base with the enhanced throw below the mounting plate.
After install, the pin is worthless because it will not snug to the top of the I slot.
Personally, I do not know why it was even there in the firts place but after removing, I certainly wouldnt wantit jiggling around into the control arm linkage.
To CHANGING SHIFTERS (undocumented)
