Uethane bushings for rear sways>>
Old Jul 23, 2006 | 06:20 PM
C6FirstVette's Avatar
C6FirstVette
Default Uethane bushings for rear sways>>
C6 Z51 set up... any one know who carries the upgraded bushings??
Thanky
Michael
Old Jul 24, 2006 | 09:38 PM
Black06C6's Avatar
Black06C6
Watched for a reply, none seen - yet. One question, why are you looking to change? I put ure bushings on my GTI VR6 motor mounts to help stabilize it, but I'm not sure of the advantage (for the potential expense) for the rear sways. If there is a compelling reason, I'm all ears as I put the Z51 sways on both front and rear without any problems with the supplied bushings. No 'squeeks' as the body moves, etc. Thanks.
Old Jul 24, 2006 | 10:54 PM
kelp's Avatar
kelp
Did you try suspension technologies? I have seen Z06 sway bars out there in the ads, which is supposed to be a little lagger than Z51 (as I heard), that's a thought. If you are into rigidity, why not have a fabrication make a shock tower brace, more trouble but keeps it very level.
Old Jul 29, 2006 | 01:49 PM
C6FirstVette
Thanks for replies.... right now I am just exploring options for the Z51 sway bar set up...found source for 'performance' urethane bushings. More later
Michael
To Uethane bushings for rear sways>>
