Reproduction Chrome C6 Wheels
Old Jul 23, 2006 | 10:42 PM
uncgsigep288's Avatar
uncgsigep288
Default Reproduction Chrome C6 Wheels
If a buy a set of repro C6 wheels for my C6, will the tire pressure sensors still work properly? Anything special that needs to be done?
Old Jul 23, 2006 | 11:44 PM
BlackMark's Avatar
BlackMark
Most will accept the sensors in the standard valve stem location,but it would be best to get that confirmed.Most forum sites will clearly state it.Also make sure the sensors go back to the corner of the car where they were originally mounted to avoid those pesky DIC messages!
Old Jul 24, 2006 | 05:24 AM
timd38's Avatar
timd38
I got the Z06 style from Bob's house of wheels, a forum supporting memeber, and they work fine with the TPS.
Old Jul 24, 2006 | 07:41 AM
HITMAN99's Avatar
HITMAN99
Can the sensors be switched to another wheel/tire combo externally, or does the tire have to be off the wheel?
Old Jul 24, 2006 | 09:05 AM
BlackMark's Avatar
BlackMark
The sensor is on the inside side of the valve stem,so the tire at the least would need to be deflated and the bead broken loose to get to it.I imagine taking the tire off would be the easiest way to remove it undamaged.
Old Jul 24, 2006 | 01:31 PM
Ted P's Avatar
Ted P
bought chrome wheels from WCC and had the dealer install them for $230. Sensors work perfectly.
Old Jul 24, 2006 | 06:19 PM
zuldane's Avatar
zuldane
I bought my wheels from Zip Performance, installed at wheel techniques for $100, works perfectly.
I will say (and others I know had this same issue), the sensors do report 0 PSI for a few minutes after they've been swapped to new wheels. 3 of my sensors reset in about 10 seconds (while the car was backing up off the lift), and the final sensor took about 1.2 miles of driving before it reset and read properly.
Just make sure you have the place guarantee that if they break a sensor, they'll buy a new one and replace it... they're not cheap!
To Reproduction Chrome C6 Wheels
