It all comes down to how much air your pushing thru the motor. Again this is oversimplified so pls nobody flame me. On a NA 364 you can only move as much air as the motor breathes in. Under these circumstances 1 3/4 is more than adequate(did not take into account custom intakes and extreme high horsepower situations). When going to a blower/nitrous/larger cubes you are bringing in more air and most are going with a cam with duration leaning heavily to the exhaust side to move that air out. This is were we begin to see the advantages of a 1 7/8 or larger exhaust. Hope this helps. Please rebuke me if i'm wrong
Previous post is accurate. The 1-7/8" headers will flow better, but velocity is lower than with a smaller tube. The result is better high RPM performance, but at the expense of low-RPM & mid-range performance. Heads & cam and/or power adder (blower or nitrous) cars benefit more from the higher flow. Bolt-on and mildly modded cars don't benefit as much.
There are similar considerations with regard to the tube length. LG headers have longer tubes, and as a result, produce great TQ numbers.
Bottom line is that there really isn't that great a difference between most of the better headers. For the typical enthusiast who only races occasionally, you'd be better to make your selection based on price, fit, and finish.
Last two posts are 100% accurate. Call Andy at andacorvette.com. He'll set you straight. I went with American racing at 1 3/4. No plans to supercharge the motor (yet) so 1 3/4 was the choice.
BTW, lots of complaints out there about LG's on the c6, fit and missing parts.......lots of happy stories from American Racing. They are a little behind production cause of demand, call Andy, he most likely will have them in stock.
...bottom line...smaller ones make better dyno numbers, the larger ones make you go faster....Immeasurably faster unless you race regularly. Buy the larger ones and get the best of both worlds.
06corvette, I don't mean to hijack your thread, but if you will permit me to inquire of this comment...
I had decided on 1 3/4" with the desire for future bolt-ons, and maybe heads and cam. I visited a tuner in Northern CA who adamantly steered me away from LG's (which until then I had finally settled on and was ready to install. Instead, he recommended Kooks, Dynatech or Bassani. Thus I put myself on hold again). He said the LG's were prone to leaks from poor build quality. Is this one such issue you are referring to? If so, I've somehow managed to miss them. Thanks.
Again, 06corvette, apologize for the slight tangent. Just after the best header (as many as there may be)
well,this thread kind of answered some of my questions too!!!I would like to know if just headers(with no hi-flow aftermarket cats,just stock ones) is ok for the c6 since I hear the c6 cats are higher flow than the c5's were.
Just passing along what the vette tuner in Northern CA told me: He said to keep the stock cats. That way it will pass the sniffer test. It will also pass the visual except for the headers, but some may look the other way given that it passes the sniffer anyway. He told me that high flow cats will neither pass the visual nor the sniffer. In addition, he said h/f cats only add a couple of hps and are not really worth the money unless you're straining for every ounce of hp with no where else to look. Again, this is only what I was told. I have no actual experience in this area (yet), but they do tune alot of vettes.
The STOCK cats WILL NOT work with ANY aftermarket headders (except callaway IMHO are a waste of $$$)
The stock cats are located right off the stock headders and are large
When you put long tubes on the cats have to go UNDER the car
Actually, (IMHO) the step headers will give you the best all around results. The downfall is that there is only 1 manufacturer at this point. The step headers will help you maintain low end torque for street use.
Tuners will tell a different story. Depends on engine mods. Each has there advantages.
