I have an '06 MN6 F55 coupe which has 3.42 gears. Sixth gear is totally useless so hopefully that will change with the 4.10 that DTE is installing this week. Also, one of the first mods I got was a B&M precision short shifter which I love.
Robin
I'm suprised you are having it trailored to DTE. If you don't mind me asking, where do you live or how many miles away. Have you thought about driving in?
That's a sweet combo, color and performance. I've always wondered what the F55 would be like with the T1 or Z51 sway bars and some 2-piece slotted rotors. Now with that 4.10; you'll have some snap in your step!! Best part about gears is that they are hard to spot by the dealership!! So you've got a good setup there!!
JK
You might want to read the entire thread...
Originally Posted by rgcarmack14
It is own its way to DTE right now for the Stage 2 package. Getting the differential out wasn't as bad as expected. It took my buddy, who owns a transmission shop here, about 2 hours to get it out but he has a lift which makes life so much easier when doing things like that.
Why not just leave it stock if you're not going to race?
Because I hate the 3.42 gearing and I just enjoy spirited driving. Racing, in my opinion, has nothing to do with enjoying driving the car and experiencing the torque that these cars offer. \
At the 6500 redline here's where I top out in 1 through 4:
1: 43
2: 62
3: 90
4: 128
First and second go by so quick it's hard to imagine them being any faster without wondering if the frequency of shifts is hurting your time for straight line acceleration. Third gear is where the real fun is at with plenty of torque between the reasonably streetable speeds of 45 and 90. Fourth pulls well all the way to 130+. By the book it should be only 128ish at 6500, but I've seen 135 before it cut off.
My car is cammed to about 500hp so my minimum crusing RPM is a bit higher than normal, but this works out well since 6th runs slightly higher RPMs now.
0-100 in my current configuration is in the low 8 second range.
In my experience the 3.9s are a good fit for my car and driving needs, but I think it really depends on what you intend to use it for. If anything, at least you'll be getting something that's stronger than the stock diff. Good luck.
1: 43
2: 62
3: 90
4: 128
Thanks! I really am excited about the difference in the response of the car. My car is cammed as well so can you tell me what your RPMs are in 6th gear cruising around, say, 70 mph?
Neither. 3.73:1 is the perfect gear, especially for an LS2.
Hittman, why the recommendation for the 3.73's? Is it a compromise so that you still get good mileage? I would think from a pure performance standpoint the 4.10's would be the way to go unless the car has been modded heavily.
Robin
6th gear, by the way, is strictly for low revs and high gas mileage when cruising. A useless 6th gear...by the way...is one where you are in 6th gear on the interstate pulling 2400 rpm at only 80 miles an hour, getting 24 mpg instead of 29. If you need some punch, just downshift. That's why you bought a manual transmission. Or maybe not.
I came from a 3.73 gearing so the 3.42 is a joke. I have downshifted and it is still pretty pitiful in my opinion.
4.10's without a doubt if its for the street. If you plan to mod and race then it will depend on HP/Trap speeds.
They both cost the same, go with the 4.10's and don't look back. Have them slip in a hardened output shaft too
The shaft will be your weak link with the mods U already have. A cheap insurance policy
It was brought to my attention that adding 3.90s would make my car equivalent to a Z51 manual tranny in gears 1-3, but after that it would be much lower geared with the 3.90s.
As far as spirited driving, I have owned many BEASTS and I think the BASE C6 MN6 has plenty of GRUNT.
I'd hate to change gears and alter the way Chevy has balanced this car.
I think the Z51 manual is geared very well for stock and lightly modded cars and even for highly modded cars with stock 3.42 gears.
I think the BASE manual would be better once you crank up the power with a Supercharger or heads and a cam. The lack of torque multiplication with the taller tranny gearing would prove to be an asset in the traction department for those who track their cars and even for spirited driving.
So, for me I am sticking with my stock 3.42s, heck my Viper only had 3.07s and it pulled like nothing else I have ever driven.
