ZO6 catback
i'm planing to do it. is it going to fit?
I have an 06 A6
First, the ZO6 pipes are 3" form the head pipes all the way back vs.
2.5" for the std pipes.
Second, You'll need to set up a vacucm activation set up and an method of turning the vacuum on and off ( a Vacuum solenoid will work) to get the baffles to work and I'd add a vacuum accumulator to avoid any changes to engine manifold vacuum whne they are activated.
Third, since you have an auto Trans , there may be interference as some aftermarket exhaust will fit a 6 spd but not an auto so the large diament pipes may present a problem.
hope this helps.
Pat
http://forums.corvetteforum.com/show...ht=Z06+exhaust
