Can u not pull codes on 07 c6?????????
Old Aug 3, 2006 | 05:13 AM
boomer 33's Avatar
boomer 33
Default Can u not pull codes on 07 c6?????????
Don't see how to do it in manual or on the searches here? Have brand new coupe with ABS problems and need to pull codes
Any help would be great!
Old Aug 3, 2006 | 06:10 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
So far the best answer I've seen here is to buy an Actron code reader from Wal Mart for $68. I don't think you can do it through the DIC anymore.
Old Aug 3, 2006 | 08:25 AM
boomer 33's Avatar
boomer 33
OK thanks, I have the big actron reader but it cant communicate with it for some reason, may not be ready for the 07
Old Aug 3, 2006 | 08:54 AM
BEZ06's Avatar
BEZ06
I'm assuming your scan tool is enabled for the CAN protocol, which is required to communicate witht the bus on the C6.
If so, take a look at this thread:
Scan Tool Thread
In that thread owners talk about problems getting their scan tool to work. I think they found that you have to get in, close the door, hook up the tool, then put the ignition in ACC mode. Take a look at the thread and see if anything in their might help.
Bob
Old Aug 3, 2006 | 11:53 AM
boomer 33's Avatar
boomer 33
I called the Service Manager, he said it is throwing so many codes it is taking foever to track them down.
I think he ought to clear them all out and see what happens then?
Old Aug 3, 2006 | 02:42 PM
boomer 33's Avatar
boomer 33
Got it back, no more codes. No real explanation was obtainable. Showed all computers lost communication becasue of low battey power but the battery is fine and was showing 13.9 when I pulled out of the dealership before this all started happening. Who knows. Probably not the end of it. Probably will not be the end of it and will eventually become a battery internal short or maybe the negative battery terminal was just a hair loose from the facotry. Who knows. At least it is back on the road.
Old Aug 3, 2006 | 09:54 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Let's hope for a one time fluke! Hope it doesn't happen again.
Old Aug 4, 2006 | 10:54 AM
boomer 33's Avatar
boomer 33
Unforunately happend again, then cleared itself after a few minutes, then repeated and never cleared again, even overnight. The voltage was showing 14.2 volts this moring when I dropped it off at the dealer again. The guys at the dealer have beeen fantastic to deal with. Very responsive, courteous, have taken the vette back into the bay immediately and hooked eveything up as if it were a patient on life support.
Yet, I think I am gong to let this one go and get another. Don't know that I can ever trust it taking that freeway ramp in the rain , runing the "pig Trail" at night. If they can't come to an exact dignosis and fix today, I am going to bail.
Now has 109 miles on it.
To Can u not pull codes on 07 c6?????????
