Quick question for double roller timing chain guys
Old Aug 3, 2006 | 09:24 AM
glueman's Avatar
glueman
Default Quick question for double roller timing chain guys
Can you swap the cam (ie. remove the cam gear) without removing the oil pump bolts and moving the oil pump forward?
Old Aug 3, 2006 | 09:54 AM
CYA-Vett's Avatar
CYA-Vett
No. You have to remove the damper to see the timing mark on the crank. To remove the damper the oil pump has to come off. Don't bother changing the chain, the LS2 chain is very strong, it's that same one the Z06 uses.
