I am installing an LS7 in my C6 Convertible and it is more of a job than I thought. Finally after new harness and ecm it started up and everything is working...except the gas pedal - what a bummer. Now we are searching for a way to fix this.
It idles very smooth compared to my ls2 which was quite modded and I should have more HP with just headers, intake work and Jeremy tune.
That is if I can get the gas pedal working - I guess I may have to just go slow as I figure it should idle at about 35-40 mph in 6th gear.
If the Corvette Z06 came in a convertible model, I would be driving one right now. The only reason I didn't get a Z06 is it did not have a removable top/drop top...EOS
Beautiful car you have BTW! Maybe a write up on your build it yourself Z06 Vert when it is all said and done.
Mike Norris at Next Level Perf can help you. My buddy JP's car just turned 10.84 at 127 Saturday night in the heat (around 3800 DA) with his LS7 C5 tuned by Norris. He did go with a slightly bigger cam designed by Norris.
It's a great mod - and not so bad money wise, as it will run with some high dollar tuner cars but gives daily driver reliability and much less cost than the twin turbo solutions and more driveability. I thought JP was crazy at first but seeing his sano install and seeing the results convinced me.
How do I get in contact with Level Perf if I need to?
Mike Norris at Next Level Motorsports @ 407-869-7223 he will certainly know. Tell him the South Florida Horsepower Sales/Corvette Challenge guys sent you! Mike a great guy and very knowlegable, does great work for all us and just finished JP's LS7 car. We were all really impressed with JP ran his 10.84 last Saturday.
I'm not bashing you, but if you had to look back at the process, would it have been easier if you started with a Z06 and then put the convertible parts on it?
Absolutely not. The Z06 is built a certain way, utilizing it's hardtop design to provide rigidity due to it's high HP and aluminum frame among other factors... If you chop the Z06 into a convertable, it would probably handle much, much worse, as well as be extremely unsafe.
Well by that theory....sticking that motor into a convertible isn't a good idea either. Putting a lot more horsepower into a car that isn't as rigid to begin with and one that wasn't designed to handle that much power is gonna make it handle much, much worse, as well as be extremely unsafe. GM doesn't offer a Z06 convertible for a reason.
What I was asking him is if he thought it would have been easier to accomplish what he did by starting with a Z06. As an engineer I can take care of the stiffness and handling problems. I want to know the best way to get a Z06 motor and a Covertible body in one package.
Well actually since we have a steel frame vice the ZO6's aluminum frame, C6's start out stronger. If you had to go one way or the other, I think he chose the wisest and safest route. The ZO6's frame can't take the power the engine produces without the hard top. I am not sure if the standard C6 frame can or cannot, but it has a much better chance.
Exactly. And that is also a reason why they use the base C6 to make the C6R instead of the Z06...
Actually now that it is done it would be easy for the second one, this was the first time my tech has ever tried this. We tried it with the regular ecm and wiring harness and the crank sensor would not talk to the ecm so no start. After the new wiring harness and ecm and rewire the throttle it is great. On the ecm we had to download a program from a Z06 using the Z06 V.I.N. I believe I will have more horses with the LS7 over my modded LS2 and be much smoother only mods on the LS7 are Long Tubes, Halltech filter, and Jeremy is going to port the intake and put a tune on it - My LS2 was about 460 RWHP. The LS7 is much smoother than that. If anyone needs any help doing this just email me at rsbb@att.net
