Dry sump for LS2
Old Aug 8, 2006 | 05:39 PM
BATMAN06's Avatar
BATMAN06
Default Dry sump for LS2
Anyone put a drysump kit on a C6 LS2 yet? I was thinking about doing it for roadracing purposes! If so, can you fit the C6 Z06 drysump system on and what part numbers would you need to do that? Would it be worth it or not? Thanks in advance!
Old Aug 8, 2006 | 05:45 PM
johnodrake's Avatar
johnodrake
Moderator
One issue would be relocating the battery and all that that entails. But it would be cool!
Old Aug 8, 2006 | 07:55 PM
excessive81's Avatar
excessive81
what y ou mean all that that intails....move the battery and run a longer wire to it and a new ground to the frame...quite simple actually and will probably do it when i install my sub and amp.
Old Aug 8, 2006 | 08:15 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I read that the oil tank, lines and fittings ran in the neighborhood of $1000 from GM. Cheaper through a vendor. A battery bracket for the rear storage compartment is available as well.
Old Aug 8, 2006 | 11:06 PM
BATMAN06's Avatar
BATMAN06
I knew about the battery deal, I was really wanting to know what parts I need...like the canister, oil lines, etc. thx
Old Aug 9, 2006 | 05:39 AM
Sparky65's Avatar
Sparky65
Pan and pump are different also. Maybe some other assorted parts on the front of the engine - not sure.
Old Aug 9, 2006 | 04:01 PM
johnodrake's Avatar
johnodrake
Moderator
All that entails ---
Battery bracket
vent/vent kit
longer wire of the correct guage
new ground location
Make a hole for the vent/wires
I was just too lazy to type it all out....
Old Aug 9, 2006 | 04:29 PM
BATMAN06's Avatar
BATMAN06
So far what I've found out is that the oil pan, lines, and canister run about $1300.00 or more. Don't know how worthwhile this might be!!!
Old Aug 11, 2006 | 12:31 AM
excessive81
go with optima no vent tubes
Old Aug 11, 2006 | 12:58 AM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
www.drysump.com
I've used a couple of their systems on LS1's and they work real good. He should be able to help you out.
Chuck @ HPE
281-448-1300
Old Aug 13, 2006 | 12:12 PM
AFTERBURN's Avatar
AFTERBURN
The pump, pan and pick up are completely different.
The pump is a dual gerotor, one for scavenging. Which will require new front cover.
Why would you want to do this. Designed for sustained G's.
To Dry sump for LS2
