Best intake system for 07 C6
Old Aug 14, 2006 | 06:04 PM
lkrassner's Avatar
lkrassner
Default Best intake system for 07 C6
I'm installing the Corsa sport exhaust system. Which intake system will provide the best results without having to cut the radiator shroud? Also, will my car need to be programed or tuned after installing the new intake system?
Old Aug 15, 2006 | 08:24 AM
AFVETTE's Avatar
AFVETTE
I first had the SLP Blackwing but my car surged and threw some code and an CEL. I never could find out what was wrong so I returned it. I then bought the HALLTECH Stinger, not only does it fit and looks nice, I have no surging or CEL. I haven't dyno'd it yet, but I got a deal on it and if I only gain 5 to 10 RWHP it's worth it to me.
But unlike the C5 which seemed to respond better to intakes, the C6 OEM intake seems better engineered. So if you have $$ to spend and are looking to mine every last pony still in the barn, than an aftermarket intake will help.
Just don't expect the BIG 10 to 15 RWHP gains seen on the C5 LS1/LS6.
Tom
Old Aug 15, 2006 | 09:12 AM
lkrassner's Avatar
lkrassner
Default Halltech
Originally Posted by AFVETTE
I first had the SLP Blackwing but my car surged and threw some code and an CEL. I never could find out what was wrong so I returned it. I them bought the HALLTECH Stinger, not only does it fit and looks nice, I have no surging or CEL. I haven't dyno'd it yet, but I got a deal on it and if I only gain 5 to 10 RWHP it's worth it to me.
Tom
Tom,
Did you have to cut the radiator shroud to make it fit and did the computer software need to be reprogrammed?
Old Aug 15, 2006 | 10:19 AM
HITMAN99's Avatar
HITMAN99
The answer is no to both ---- no need to cut the shroud, and no need for reprogramming. Halltech also offers a true cold-air option, it's a replacement for the front fascia that fits behind the grille, has screen openings on either end to let cool air in. If you have access to a Dremel tool or an air-powered cutting tool, you could probably just cut an opening in the fascia, accomplish the same thing.
Old Aug 15, 2006 | 10:35 AM
AFVETTE's Avatar
AFVETTE
Originally Posted by lkrassner
Tom,
Nope, it's plug and play.
Tom
Old Aug 15, 2006 | 10:36 AM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
I'm really a fan of the Callaway. Yes it requires cutting the shroud, but that piece is not extremely expensive for if you decided to go back to stock in the future. For the performance you'll see, I would consider it money well spent.
Any good intake system will usually require a little tuning afterwards. Nothing too radical, but a few tweaks wouldn't hurt. The computer will compensate though, so if you decide to wait on a tune till you do more to the car, it won't be that big of a deal.
Chuck @ HPE
281-448-1300
Old Aug 15, 2006 | 10:46 AM
robotpedlr's Avatar
robotpedlr
I went with the new Vararam. It works great and the new improved model fits and looks great also. You can either cut the shroud or order a pre-cut shroud like I did. Based on some other posters, it seems cutting is actually easier then I thought if you are careful. Anyway, you can read the review I posted after my install on here
http://forums.corvetteforum.com/show....php?t=1433588
Old Aug 15, 2006 | 03:20 PM
yell03's Avatar
yell03
I think to gain max performance you ned a Bottom Breather like the Vararam, but there is a risk of Hydrolock.
I had one ordered and I cancelled it for my daily driver C6.
On my other C6 I did not do an intake and ran a 12.57@110.67 with just a Magnaflow catback.
On my 2006 C6 I am doing Corsa Sports and will decide later on if I want to go with a Halltech most liekly.
Howard
Old Aug 16, 2006 | 02:31 AM
vette6500's Avatar
vette6500
Tom
That's a HUGE filter!!!
I didn't realize those aftermarket filters were that big. I was thinking if the filter was smaller, I could just cut some openings in the shroud to the left and right of the filter to allow some more air in without the risk of dangling a cold air intake down low. Is the K&N filter also that big on their intakes?
Old Aug 16, 2006 | 06:07 AM
shopdog's Avatar
shopdog
There's only one good aftermarket intake for these engines, the FAST. That does require cutting the firewall, and modifying the fuel injector rails, to make it fit. A tune will be helpful after you change the intake. BTW, while the intake is off, that'd be a good time to drop in a cam too.
Old Aug 16, 2006 | 07:06 AM
timd38's Avatar
timd38
I have a K&N and it is about the same size.
Old Aug 16, 2006 | 07:28 AM
yell03's Avatar
yell03
If I do a Halltech or K&N, I am sure later on I will either fab my own cold air ducting or buy the Halltech Cold Air option for an extra $129.
From what I can see there would be NO CHANCE of Hydrolock with this set-up.
Howard
Old Aug 16, 2006 | 08:38 AM
midnite902's Avatar
midnite902
In my opinion there is no better intake than the LPE CAI. I tried the Halltech but when I switched the difference in power was noticable in SOTP and on the dyno.
LPE CAI
Stock - Halltech - LPE CAI
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I Love my Big Honker
Borla Catback + Calloway Honker CAI got 22 RHWP 4 me
Old Aug 16, 2006 | 05:00 PM
tluck's Avatar
tluck
Same here, but I cut the shroud with a dremel tool and did final trimming with a sharp box cutter knife. Not a problem to install.
Old Aug 16, 2006 | 06:32 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Chuck @ HPE
281-448-1300
100%
Old Aug 16, 2006 | 08:50 PM
Stingray23's Avatar
Stingray23
How difficult is it to install the Callaway? Thats the intake I'm leaning toward. Its either gonna be the Callaway or the Lingenfelter.
Old Aug 16, 2006 | 09:23 PM
mcv's Avatar
mcv
The installation instructions are on the web site if you want to get an idea of what's involved.
www.callawaycars.com, then "Downloads", then "Installation Instructions".
To Best intake system for 07 C6
