Need info please on gears
Old Aug 16, 2006 | 02:39 PM
par34n5's Avatar
par34n5
St. Jude Donor '06
Default Need info please on gears
I want to put gears in the car verses a cam for warranty reasons. I figured I can hide the gears but not the cam. I have a c6 6 speed manual with magnetic ride. I do not want to go with 410 rear I figured I would be shifting way too much. I was thinking of going with 390's. Any input would greatly help Thanks Guys
Old Aug 16, 2006 | 02:51 PM
Buffy's Avatar
Buffy
Here are some charts for quick comparison: http://mysite.verizon.net/foofoo2/c6/ - just click the 'gear' in the table for the transmission and gear combination to get a chart.
You didn't say 6 speed manual or auto, but assuming the manual there's not a lot of difference between the 3.90 and 4.10 - about 100 RPM cruising in 6th at 70 MPH.
VET4LES's Avatar
VET4LES
Originally Posted by par34n5
I want to put gears in the car verses a cam for warranty reasons. I figured I can hide the gears but not the cam. I have a c6 6 speed with magnetic ride. I do not want to go with 410 rear I figured I would be shifting way too much. I was thinking of going with 390's. Any input would greatly help Thanks Guys
I don't know about hiding it from GM. You will need a tune to handle the new gear ratio and GM will know about that.
Old Aug 16, 2006 | 03:23 PM
TXSTICK's Avatar
TXSTICK
I put 373s (because I already had them) in an 04 Mn6, they made a very nice difference, but 390s would have been perfect. No programming with the Mn6.
Old Aug 16, 2006 | 04:46 PM
tluck's Avatar
tluck
I've had both. Go with the 4.10's if you have a 6 speed.
Old Aug 17, 2006 | 01:41 AM
TTRotary's Avatar
TTRotary
Why do you need a tune on a manual car?
Old Aug 17, 2006 | 04:19 AM
crabman's Avatar
crabman
No tune required on a stick car. You wont notice the difference between the amount of shifting between the two gearsets so I wouldnt make a choice based on that alone. Based on what little information you gave in your post Im guessing you dont need to worry about not being able to finish the 1/4 in fourth with the 4.10s. What are your other priorities that might affect your decision? Im 3.90 myself and not trying to talk you into one or the other but a little more information might get you more pointed information.
Old Aug 17, 2006 | 08:02 AM
CYA-Vett's Avatar
CYA-Vett
4.10's without a doubt!
Old Aug 17, 2006 | 12:18 PM
jsk96z28's Avatar
jsk96z28
Wont the speedo be off if you dont tune?
Old Aug 17, 2006 | 12:21 PM
CYA-Vett's Avatar
CYA-Vett
Corvette measure the speed at the axles, not tranmission, auto requires tuning for shift points, manuals are good to go.
Old Aug 17, 2006 | 07:16 PM
par34n5's Avatar
par34n5
St. Jude Donor '06
Default works great
Thanks it really helps to see what I am going to get
Old Aug 17, 2006 | 07:18 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
DTE also has a nice chart on their website as well.
To Need info please on gears
