1-3/4" vs. 1-7/8" LT Headers
Old Aug 17, 2006 | 10:11 AM
TXVette06's Avatar
TXVette06
Default 1-3/4" vs. 1-7/8" LT Headers
I am not planning on going radical on mods for my 6-spd manual C6. I am looking at the Kooks long tube headers with x-pipe and cats. Does anyone have dyno numbers for the 1-7/8" and 1-3/4" sizes? I have read that the smaller size will give me more low end torque.
Old Aug 17, 2006 | 10:12 AM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
I went with the 1 7/8 and had them jet hotted
Old Aug 17, 2006 | 10:19 AM
TXVette06's Avatar
TXVette06
How do you like them? What other mods do you have? What kind of gains did you see from the headers?
Old Aug 17, 2006 | 07:11 PM
burtonbl103
Putting them on this weekend
Here are some pics
Old Aug 17, 2006 | 08:16 PM
italiangod79's Avatar
italiangod79
Default headers
what did u pay for that setup? Also what kinda exuast are u hooking into?
Old Aug 17, 2006 | 08:19 PM
burtonbl103
$1800 with jet hot coating from tbyrne forum vendor
hooking up to corsa sport setup
Old Aug 17, 2006 | 08:41 PM
italiangod79
Default headers
Wow thats a sweet setup
Old Aug 17, 2006 | 09:29 PM
GTB/ZR-1's Avatar
GTB/ZR-1
1 3/4" will be fine w/ a 6.0L. and you'll lose some TQ w/ the larger headers. The 1 7/8" work better on a bigger CI engine or a more radical higher-RPM buildup.
Old Aug 17, 2006 | 10:08 PM
burtonbl103
I was told by many people on the ls2 to go with the 1 7/8
You may loose 3 to 5 Tq in the mid range on a stock ls2
But i see the lpe 403 package in my future !
since i do not want to get raped buying a z06
Old Aug 18, 2006 | 12:29 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
I have 1 7/8 on mine,and it really helps w/ the 'MAGGIE' I have!
But a larger size header is a good idea to get,in case you get some other mods down the line!
Old Aug 18, 2006 | 01:59 AM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
I always recomend 1 7/8 because most people end up doing more to their cars in the future that will require the use of larger tube headers. The only time I ever install 1 3/4 is if the customer absolutely insists that he "needs" them But I personally have never seen a 1 3/4 header out perform a 1 7/8.
One thing you need to be careful on is coatings... Ceramic coatings will hold heat into the exhaust and cause detonation problems. Therefore cars with ceramic coated headers usually require more fueling and less timing to fix this problem... 2 things that obviously restrict hp... A set of nice uncoated stainless steel headers will do the trick, both in making horsepower, and lasting a very long time.
I would recomend a set of 1 7/8 American Racing stainless headers. The American Racing headers have a merge collector that will help torque by increasing velocity at the collector.
You can call me if you have more specific questions. I'd be happy to help you out...
Chuck @ HPE
281-448-1300
Old Aug 18, 2006 | 07:35 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Sweet set up Bill
Hope the install goes well 4 U
Old Aug 18, 2006 | 09:40 PM
burtonbl103
Originally Posted by JFTaylor
Sweet set up Bill
Pics to follow
Old Aug 19, 2006 | 12:44 AM
sallen619's Avatar
sallen619
Chuck @ HPE
281-448-1300
Went to the HPE website and you sell the Kooks....no American Racing...
Old Aug 19, 2006 | 02:20 AM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
Yeah, website is old, never have time to mess with it. I'm having a new one built though right now that will have lots of new features. Call or email if you need information on anything!
Thanks,
Chuck @ HPE
281-448-1300
Mon-Fri: 9-7
Closed weekends
Old Aug 22, 2006 | 06:10 PM
Nukecop's Avatar
Nukecop
St. Jude Donor '05
one thing you need to be careful on is coatings... Ceramic coatings will hold heat into the exhaust and cause detonation problems. Therefore cars with ceramic coated headers usually require more fueling and less timing to fix this problem... 2 things that obviously restrict hp... A set of nice uncoated stainless steel headers will do the trick, both in making horsepower, and lasting a very long time.
what about jet-hot's STERLING coating? just the outside of the header or both inside and out.
Old Aug 22, 2006 | 08:12 PM
burtonbl103
Thanks what i did and no problems so far
Old Aug 22, 2006 | 08:21 PM
CYA-Vett's Avatar
CYA-Vett
Isn't this the truth. How many of us have said "this is my last mod"
I lost 4 HP with the 1 7/8 primaries, but then again I gained .4 in the quarter mile. Dyno sheets lie, they are for tuning, not testing parts.
If you want a dyno queen go with the smaller ones, if you want your car to perform go larger.
Old Aug 22, 2006 | 08:48 PM
burtonbl103
This is why i went with this 1 7/8
This is my last mod
To 1-3/4" vs. 1-7/8" LT Headers
