Rough bumpy road multiple DTC codes
There is a lot to be desired in 'consumer' grade radios, and a little careful work in this area paid great dividends.
Same thing when I bought a mexican Fender Stratocaster to play around with. With a little copper cladding to build a faraday cage into the body and pick guard, and careful grounding and shielding work, including use of small sheilded coax in the body, it became an amazingly quiet and hum free guitar in all pickup configurations, including of course, hum-bucker.
Like this:
http://www.guitarnuts.com/wiring/shielding/shield3.php
http://ratcliffe.co.za/articles/hotrodshield.jpg
So I wonder if it would be worthwhile to simply install a completely seperate and redundant grounding arrangement in order to eliminate such issues. Technically, it would cause 'ground loops' if the existing wiring is left behind (which I would recomend), but for our 12VDC systems, I don't think that is an issue at all, even for radio antenna performance. If some wire is good to ohmically connect point to pint, extra wire can do no harm...
I would not do it to a healthy C6, but if mine persists with odd symptoms, I'll take it in. But if they fail to find it, I think some checking/paralleling of existing ground could not hurt.
Flame suit on.
