adjust cluch pedal
Old Aug 18, 2006 | 12:22 PM
TRACKMAN2's Avatar
TRACKMAN2
Default adjust cluch pedal
is there a way to adjust the cluch pedal on a 02 z it catches right at the verry end of the throw ,, the dealer says no but i cant believe the isnt a way.......
Old Aug 18, 2006 | 12:27 PM
Hoonose's Avatar
Hoonose
I think you want the C5 tech forum....
Old Aug 18, 2006 | 12:36 PM
Ranger's Avatar
Ranger
Yes, the LS6 clutch can have the engagement point adjusted. The procedure is in the service manual. I'd look it up for you but sold the manuals when I sold the 02Z.
I had my installer make the adjustment when he installed a fresh clutch in my 2002 Z06. Wanted to ensure the engagement point was near the top, e.g. pedal nearly all the way out. A low engagement point leads to missed shifts.
This subject comes up from time to time. At least one member has insisted that the adjustment would be done through the inspection cover.
http://forums.corvetteforum.com/show...2&postcount=13
http://forums.corvetteforum.com/show...7&postcount=22
http://forums.corvetteforum.com/show...2&postcount=23
Boosted_Z06 never responded and I don't know if his information is accurate.
Ranger
Old Aug 18, 2006 | 12:37 PM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
You need a Mcleod Adjustable Master. It's a good upgrade from the stock one and will support a heavier clutch in the future if you decide to upgrade.
Chuck @ HPE
281-448-1300
Old Aug 18, 2006 | 01:11 PM
Irv's Avatar
Irv
How does the Mcleod unit install?
To adjust cluch pedal
