Does this sound like a active handling error?
Old Aug 19, 2006 | 06:29 PM
aTX427
Guest
Posts: n/a
Default Does this sound like a active handling error?
Took a drive out to the hill country today and had the active handling kick in twice on down hill high speed right hand sweepers. I was running about 85-90mph with no signs of traction problems and the car started studdering. I was like what the - came off the gas the car settled down and I ignored it. The next time it happened, I looked down and saw the display showing the active handling message. I was not even pushing the car at all. Felt like I could have been going 15-20 mph faster without breaking a sweat.
I have upgraded suspension components (C6z06 sways / springs) and have a lot of rubber on the ground (275-front / 345-rear). Other than that, the car handled flawlessly. Highly recommend the suspension upgrade.
Could the sensors have a max g-rating that was ofercome, regarless of actual traction?
Old Aug 19, 2006 | 06:31 PM
VET4LES's Avatar
VET4LES
That's what it sounds like to me. I have seen the light when one rear wheel spins a little in gravel.
Old Aug 19, 2006 | 06:47 PM
rcwck's Avatar
rcwck
It might be interesting if you test your car on the same road in "Comp Mode". The AH is supposed to be less sensitive in this mode. The couple times my AH kicked in I was in "Comp Mode" and I could feel the brakes working and I would say the car was just about to turn around.
You are talking about AH and not TC?
Old Aug 19, 2006 | 07:08 PM
Ranger's Avatar
Ranger
C6Z hit the wall at Moroso today. Did a 180 on the 2-3 shift. Running with AH-Off.
Anyone thinking they may be better off with AH-Off may want to reconsider.
Ranger
Old Aug 19, 2006 | 08:15 PM
aTX427
Guest
Posts: n/a
I was running in with the standard settings. Left everything on.
Old Aug 19, 2006 | 08:25 PM
Ranger's Avatar
Ranger
I don't doubt that. But anytime an owner posts a story like yours in post #1, it draws the standard "AH is for pussies" comment from the usual suspects. I omit from that group the small handful of road race drivers, active and retired, who hate all the handling assists of the C5/C6.
Ranger
Old Aug 19, 2006 | 11:12 PM
aTX427
Guest
Posts: n/a
Agreed - I will not drive without the sensors on. I am not racing and they saved my *** a few times. I just found it strange that either I outdrove the sensors or the car's set up is better than the sensors baseline or lastly there is a problem with the sensors.
Old Aug 20, 2006 | 12:12 AM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
Sounds normal to me. At the track I start the day with everything on as I warm up. Within a couple laps AH starts coming on all the time even though it seems like there's no reason to.
Old Aug 20, 2006 | 12:35 AM
kelp's Avatar
kelp
AH, TM, TC - turn it all off. The car feel is so much safer and more stable without them, you can feel what it does. Just be sensible. If you really can't resist the gas, better use the trailer wheels.
The only unpredictable element is brake lock up, therefore keep that on. That might be due to the tires, or brakes, I don't know. Try it both ways and see.
Old Aug 20, 2006 | 12:48 AM
Ranger's Avatar
Ranger
Originally Posted by kelp
AH, TM, TC - turn it all off. The car feel is so much safer and more stable without them...The only unpredictable element is brake lock up, therefore keep that on. That might be due to the tires, or brakes, I don't know. Try it both ways and see.
As a C6Z06 owner at Moroso dicovered on Saturday, unpredictable elements include oil, tranny fluid, anti-freeze spilled on the track surface. His resut with AH-Off plus spilled fluid = 180 degree spin and a wall impact with the rear of the car...without insurance coverage. Body and suspension damage; unsure about the frame.
Ranger
Old Aug 20, 2006 | 02:23 AM
kelp's Avatar
kelp
As you wish.
Old Aug 20, 2006 | 02:55 AM
glennhl's Avatar
glennhl
I don't think you can turn off ABS.
Old Aug 20, 2006 | 03:13 AM
kelp's Avatar
kelp
It's one of the fuses. The stock brakes and runflats do not give much warning, they just lock up.
Old Aug 20, 2006 | 08:24 AM
aTX427
Guest
Posts: n/a
what settings do people typically run for track days? Competitive mode?
Old Aug 20, 2006 | 10:00 AM
02impactblue's Avatar
02impactblue
Based on my track experience with the c6 the AH is very unpredictable. I always ran the c5 in comp mode but the c6 is undriveable on the track with AH on/comp. I've had times where it cuts fuel and applies the brakes very hard in mid corner when the car was in perfect control and I had other times when the tail of the car was way outta shape and it never kicked in. The c5 system was very good the c6 system is terrible. This is just my opinion.
Old Aug 20, 2006 | 10:17 AM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I see no reason to put himself, and more importantly his car , at risk. Running with everything off on a hilly street is way to dangerous IMO. At the track or a real open area without possibility of collision is up to you. But on the street....
Old Aug 21, 2006 | 01:57 AM
mlongo99's Avatar
mlongo99
That's what I do.
Interesting. I have the opposite experience with the C6 in comp mode. I find it to be quite predictable, and that when it activates it is fairly subtle.
To Does this sound like a active handling error?
Old Aug 21, 2006 | 02:04 AM
shurite44's Avatar
shurite44
When AH is working on a sweeping turn it is difficult to feel unless you really start to get out of shape. I think yours is working properly.
I agree with Ranger also, keep it on. I totaled an 03 coupe with it off. I think it may have saved me if I had left it on.
Most important, if you turn if off don't forget about it. That is what bit me in the a$$.
Old Aug 21, 2006 | 02:08 AM
shurite44's Avatar
shurite44
First off, I disagree. Bad advice in my humble opinion.
Second paragraph does not make sense. You can not control the mode the brakes are in. Unless you are referring to AH. But your ABS system stays on all the time.
Old Aug 21, 2006 | 10:57 AM
kelp's Avatar
kelp
After reading the extensive pros and cons posted about AH, it can be derived:
- The system is very complicated
- This is a widespread application of new technology
- Few entirely understand it
- The results are variable at best
- Some people received life-saving results
- Some people received life-threatening results
and
- Opinions are very decisive on this topic
Everyone has a different driving style, application, vehicle, modifications.
The decision to use the AH program involves evaluating one's individual particular requirements, evaluating insurance endorsement requirements, their experience with, and knowledge of the AH system.
