Taking out the shroud
Old Aug 21, 2006 | 05:40 PM
jbh2403's Avatar
jbh2403
Default Taking out the shroud
Does anyone have a how to guide as to how to take out the shroud out through the top to get a precut shroud in?....trying to get this vararam in...first slight snag...lol
Old Aug 21, 2006 | 06:49 PM
jbh2403's Avatar
jbh2403
ttt
Old Aug 21, 2006 | 07:40 PM
danielg69's Avatar
danielg69
It doesn't come out the top. Do you not have the instructions? I know the are AWFUL but they clearly tell you it comes out from the bottom.
Daniel
Old Aug 21, 2006 | 07:44 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
It does too come out the top !
Undo all of the plastic tree clips on the sides remove the air sensor on the lower drivers side from the top
then unbolt the top plastic radiator shroud and push in the middle and pull up and out
Old Aug 21, 2006 | 11:54 PM
StarJack's Avatar
StarJack
The first part of these instructions may provide some assistance. Shrouds a biotch, easier with two people, took mine out from the bottom.
http://www.westcoastcorvette.com/ima...ctions/384.pdf
Old Aug 22, 2006 | 12:13 AM
achilds's Avatar
achilds
It definitely comes out the top, I took mine out this way when I installed my cold air intake (LPE). It is a pain in the butt and takes some wrangling. Make sure you have all the little plastic clips out and give it the appropriate bend and tug. Putting it back is a little easier.
Old Aug 22, 2006 | 08:58 AM
tluck's Avatar
tluck
No need to remove the shroud. Cutting the shroud is easy and safe if you follow a few simple instructions. Remove the top radiator & A/C condenser support. Shim the shroud out with some shop rags, mark the cutout area, use a dremel tool for cutting, and then do the final trimming with a box cutter knife.
To Taking out the shroud
