St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
I am also interested in a cam-only mod.
Remember, you have to trade low-end torque to get top-end horsepower. I am sure there is a big cam that can do what you want, but it might buck and stumble at anything less than 3000 to 4000 rpm.
Look at www.cranecams.com and at www.compcams.com for some info. I BELIEVE that the LS1 cams will work in the LS2 engine, but if not, someone will correct me almost instantaneously .
So, be careful what you wish for, you might get it.
Within reasonable limits, a bigger cam (more duration) will give you more power throughout the power range (2K to 7K RPMs). It's mostly at idle and below 2K RPMs where driveability and throttle response issues will occur. Tuning techniques have improved in recent years, so that many driveability issues of the past no longer apply.
However, you will need a computer tune.
With stock heads, there are two constraints. One is that stock heads tend to "stall out" above a certain lift, where aftermarket heads won't. If you keep the lift in the .550" to .580" range, you should be OK, and be able to use single springs. The second constraint is the size of the intake runners. Stock heads have smaller runners, which is good for velocity, but bad for max airflow. So there is a point of diminishing returns for really large cams, in that the heads will only flow so much air, and high RPM performance will suffer accordingly.
You will get a zillion different opinions on what is the "best" cam. Talk to your vendor/installer, be honest in your driving style and goals, and you will usually get good advice. 430 HP is easily attainable with a number of cams.
I can tune the engine but to the gear
is it a problem?
the tranny cannot be tuned yet on the A6. a/f ratios and fan temp, etc can be tuned.
as far as cam goes, definitely get your heads worked over or at leat replace the springs and such. stock springs are suited only for the stock cam, and barely at that...
I'm thinking of installing the MTI G1 cam ni mine at the beginning f the year:
Is it your DD or just a weekend car? With that LSA and duration it's going to lope like a ****
I have A&A's version of that cam --XER 228/232--(my exhaust lobe has more lift .595) and it doenst lope much and drivability is fine. The tune was more tricky than my previous 224/230 which surprised me.
I had the G1 cam with AFR 205 heads on my C5 and I do not recommend it. It did not make good power for me at all. In fact, I ran better quarter mile times with the X1 cam and no heads. The X1 cam is way underrated. It makes power from idle to redline and way more torque than the G1 and it sounds radical, which you may not like.
The Torquer 2 cam from Texas speed is a bit larger, but made good power, had better street manners and was easier to tune than the X1 or the G1.
PS, whichever cam you get you will almost certaintly need a higher stall converter.
I have to get the springs, pushrods, retainers, and custom engine tune. (are these all the stuff that I need?)
or do I have to get a TC and tune the A6 as will.
You will also need:
Timing Cover Gasket
Front Seal
Water Pump Gaskets
Crank Bolt
You will need a TC for 2 reasone, 1. your idle will have to be raised to accomodate the cam and once it is, the stock converter will stall too early, you will wear out your brakes rather quickly since the car will want to move at idle and 2. You power curve will be raised and you will want to be at higher rpms with a cam.
The torquer 2 cam will run and idle just fine until you get a tune, I drove mine around for a few weeks, but I had an mn6.
CYA knows what he's talking about...hey Dave...sorry I haven't gotten in touch sooner....everything came in and looks to be in very good shape. appreciate the parts man. I got the intake in but have been working so much lately haven't had much time to do anything else.
definitely be concious of the biggert the cam, the more bucking you "may" get below 2000rpm...that could pose to be a much bigger headache than us with a manual trans.
Also, regarding another post by someone. I do believe AFR dual valve springs are rate up to .675 lift. which would work on the "american thunder cam" that the poster just above this post had.
