Cannot read OBD2 codes
Old Aug 27, 2006 | 05:12 PM
baf2000_1's Avatar
baf2000_1
Default Cannot read OBD2 codes
It looks like my car is in a funky mode. I cannot read OBD2 codes using a code reader. Anyone ever have this problem? ( 2005 C6 MN6 )
Old Aug 27, 2006 | 05:15 PM
BEZ06's Avatar
BEZ06
Is your scan tool CAN enabled? If it's an older scan tool, it may not read the CAN bus.
Bob
Edited to add this link: Old Thread On This Problem
Old Aug 27, 2006 | 05:46 PM
VET4LES's Avatar
VET4LES
Bob
CAN capable is required.
Old Aug 27, 2006 | 05:50 PM
baf2000_1's Avatar
baf2000_1
The scanner is a INNOVA 3030 that is CAN enabled. It seems there is no power since the display does not even come on. Could be trouble...
Old Aug 27, 2006 | 06:17 PM
VET4LES's Avatar
VET4LES
All of the newer INNOVA readers are CAN enabled, mine is model 3110 and works fine. Tomorrow you should call their help line and they will help you. I have talked to them several times and they are a big help.
Old Aug 27, 2006 | 08:51 PM
dennis50nj's Avatar
dennis50nj
did you put new batteries in and try reading in acc mode
Old Aug 28, 2006 | 01:06 AM
DJackman's Avatar
DJackman
I have the same reader as yours and it works fine. It should power-up as soon as you plug it in. If not put the ACC mode then plug it in.
To Cannot read OBD2 codes
