remove wheel
loosen bottom retaining bolt
remove top retaining bolt
swing caliper open
remove pads
compress pistons
replace pads
swing it back in place and tighten the bolts.
Does anybody know the Part No. for ceramic brake pads. My Dealer says they don't make them. I am tired of the dust. I have a 2007 coupe with the F55
Your dealer is not looking in the right place. The ceramics are available from the dealer but are marketed under something else name wise...not sure if it's AC Delco, Delco Remy or another reconized GM brand name but I'm sure someone else can clarify that info.
