Service Active Handling
Old Aug 30, 2006 | 04:31 PM
N1JF's Avatar
N1JF
Default Service Active Handling
06 C6 Z51 with about 4K miles.
Pulling out of a restaurant parking lot at lunch today I got a beep, the active handling light came on and the DIC said "Service Active Handling." Turning active handling off and on did not resolve the problem.
Next startup everything had returned to normal.
Anyone have a clue what caused this litte "transient anomoly"?
Old Aug 30, 2006 | 05:50 PM
jackv92126@yahoo.com's Avatar
Default service active handling
i had that problem too. i cannot recall what i did but pressing the reset button and turning off and on button after doing this everyday for about a week it suddenly cleared itself. i dont know what i did but the dealership told me that a wire might have came loose. i dont know but its ok now. try resetting it everytime it appears . good luck
Old Aug 30, 2006 | 10:35 PM
outnumbered's Avatar
outnumbered
Same problem.
Take it to the dealer.
They replaced a steering sensor and secured the harness at the base of the steering column.Problem solved.
I think there is a TSB.Others here on the forum told me the same thing I just told you.It is common.
Good luck
Old Aug 31, 2006 | 01:33 AM
psimms's Avatar
psimms
Originally Posted by outnumbered
Same problem.
Good luck
Yes, take it to the dealer like I did and get it fixed. Mine was covered under warranty.
Old Aug 31, 2006 | 02:05 AM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
Mine HAs Done The SAme thing Twice...But It Would just Come on real quick while i am driving and just go away...
Old Aug 31, 2006 | 06:10 AM
Radical05's Avatar
Radical05
You can take it to the dealer or in 15 min just do it yourself and save the headache. Typically its the wiring harness and there is a TSB on it. Simply pop off the panel under the steering column. At the bottom you see a big wire harness and connector. Unplug it and then plug it back in. Get a small wire tie and wrap around it so it wont come apart (loose) again as you move the steering column if you move it. I dont once its set and Im the only driver. Since I did mine the same way the dealer will IAW the TSB never got a DIC message again and no dealer headache. If I get it again then I will seek the dealer.
Old Aug 31, 2006 | 10:28 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Be sure your dealer knows there is a bulletin on this, otherwise they will pull your steering column apart to replace a sensor. The bulletin just calls for resecuring some wires and connector that get pulled loose.
Had the quick fix done on mine but i had to tell the tech about the bulletin.
Old Aug 31, 2006 | 12:44 PM
N1JF's Avatar
N1JF
Thanks for the help guys. Does anyone know what the TSB number is on this little problem? I try to make it as simple as possible for my small town dealer.
Old Aug 31, 2006 | 02:25 PM
outnumbered
I think it is common enough that they will know.
Old Aug 31, 2006 | 07:59 PM
als2052's Avatar
als2052
After reading your post a couple of weeks ago, I went looking for the panel to pop off. On a C6, where is this panel cause I never saw it.
Old Sep 3, 2006 | 06:16 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
als2052, did you ever figure out where the panal is ?
Old Sep 4, 2006 | 12:43 AM
steveo242's Avatar
steveo242
Same problem.
Good luck
Yes, I did this last week, have not had it come up since. There is a bulleting on the connector in the steering column
Old Sep 4, 2006 | 10:51 AM
06corvette's Avatar
06corvette
Exactly the same happened to me.
Old Sep 4, 2006 | 03:03 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
where is it ?? i found the plastic panel with the plastic 'push' retainers, didn't see a connector. is it on the bottom of the steering column or above the pedals in the floorboard ?
Old Sep 5, 2006 | 08:12 AM
als2052's Avatar
als2052
As far as I am concerned there is no panel.
Old Sep 5, 2006 | 09:37 AM
Zig's Avatar
Zig
pics would be helpful
Old Sep 5, 2006 | 08:26 PM
06corvette's Avatar
06corvette
I took my car back from the dealer and he did the fix under waranty.
he just found a loose wire under the steering. THATS ALL
Old Sep 5, 2006 | 08:52 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Yeah, so where is the mystery connector located ?
To Service Active Handling
