DBS is back.
Old Aug 30, 2006 | 10:18 PM
Zoltan's Avatar
Zoltan
Default DBS is back.
6 month old, new battery. Car garaged for 4 days. Shut down correctly.
Not reliable, I just wanted to jump in it and go play golf. To my dismay,
DBS.
Good thing I have more cars to drive.
Keep the key with the FOB!!!!
Otherwise you are fuc--d!!!
My only gripe with the C6, DBS, I can't freaking believe it.
And Chevy called a few months ago to see how satisfied I was with the service, and I said very!
What's the fix?
Old Aug 30, 2006 | 10:24 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
What kind of battery was it?
Old Aug 30, 2006 | 11:23 PM
Hoonose's Avatar
Hoonose
DBS.
What's the fix?
You say 6 months old car, but your profile says '05.
So I still assume it's an '05 shifter?
There is something coming out real soon from GM to fix DBS.
It's either a software fix or a different BCM module upgrade or version.
And it sounds like it will be the real thing.
It probably will also eliminate the need for the shift to reverse on shut down requirement, and possibly even the steering lock.
Old Aug 31, 2006 | 03:32 AM
not08crmanymore's Avatar
not08crmanymore
Default what's the fix??
Most who have had DBS have gotten the priority start thing and hooked it up and in most cases fixed the issue.
Old Aug 31, 2006 | 09:13 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
" fixed the issue" **Should read, PUT ON A BANDAID. **No fix, but a work around GMs big F**K UP
I talked to some GM people at Carlisle, there is possibly some light at the end of the tunnel on this issue
Old Aug 31, 2006 | 09:33 AM
not08crmanymore
Hey Dave,sorry I missed you out there!I got sick Saturday p.m. and ended up in the room till Sunday morning.
Old Aug 31, 2006 | 10:03 AM
k-line's Avatar
k-line
I'll trade. My Oil consumption problem for your DBS. You'll make your Tee times just add a quart every 1500 miles.
Old Aug 31, 2006 | 10:11 AM
6spdC6's Avatar
6spdC6
Sick so far from home no fun
Had a good time at Carlisle, saw lots from this area,+ possibly some good news by a engineer I kinda know from many visits to Carlisle (DBS stuff)
Hopeing to go to the Vette wash and show on Sunday ( 09 10) at Hadley
Old Aug 31, 2006 | 10:24 AM
Zoltan's Avatar
Zoltan
The car is an '05 MN6. The battery is a 6 month old AC/Delco Professional with a 6 year rating.
Old Aug 31, 2006 | 10:26 AM
Zoltan's Avatar
Zoltan
AC/Delco Professional, 6 year rating.
Old Aug 31, 2006 | 06:33 PM
'06 Quicksilver Z06
Why am I not surprised?
Until you replace the crap AC/Delco battery in your car with a real battery such as an Optima, you will continue to have start up problems of unknown origin/reason.
Put a decent battery in your car and there is a good chance that your dead battery woes will disappear as quickly as they showed up.
Old Aug 31, 2006 | 07:04 PM
timd38's Avatar
timd38
You believe these guys? They are ones that said there wasn't an issue. 05 manuals and 06 automatics both have DBS issues. People don't want to beleive me on the 06 auto, but trust me a module in the ECM stays on even when you turn off the car, sometime. That's what makes DBS so great, you never know when it will strike.
O5 get an auto, 06 get a manual, 07, ?........
Old Aug 31, 2006 | 09:05 PM
Hoonose's Avatar
Hoonose
If the battery and charging system check out as normal, then a prioritystart module would make the most sense and give you good security until the new upgrade comes out.
Old Aug 31, 2006 | 09:17 PM
Jbal's Avatar
Jbal
Hang in there Folks! When in Carlise last weekend, the Corvette electrical engineers indicated the FIX is on the horizon.
Take Care All.
Old Aug 31, 2006 | 09:50 PM
Zoltan's Avatar
Zoltan
I thought GM would have reliable batteries. I had faith, I am proven wrong.
I'll put in an Optima. WTF?
Old Aug 31, 2006 | 09:53 PM
Zoltan's Avatar
Zoltan
I never heard of that. Where can I get one and who installs it?
Thanks.
Old Aug 31, 2006 | 10:07 PM
German_C6_Driver's Avatar
German_C6_Driver
Thanks.
Real simple...Goggle "Priority Start"...lots of places sell 'em on-line. I bought one a bit over a month ago. Install is a DIY and real painless. Should run you about $70 w/shipping.
To DBS is back.
Old Sep 1, 2006 | 12:43 AM
Hoonose's Avatar
Hoonose
I never heard of that. Where can I get one and who installs it? Thanks.
prioritystart.com or do a search on the forum.
Many many here with '05 shifter use one and swear by it.
It may just be a kludge, but it works.
It probably should be std on any car.
If your battery drops below a certain voltage, it cuts everything off.
You come out to a dead car, but you get in using your emergency key over the rear license plate and open the hatch. Pull the door opening ripcord back there. Then get in through the drivers door and push in the cigarette lighter to restart the battery. Start the car and reset your window indexing and memory settings. You're good to go....
Old Sep 1, 2006 | 05:50 AM
timd38's Avatar
timd38
Warranty is a function of marketing.
Old Sep 26, 2006 | 12:48 AM
doon41's Avatar
doon41
1st Gear
Default DBS on '06 Auto
Thanks to you Corvette guys for this info. I just took charge of my deceased father's '06 Corvette. Dead battery, and no apparent way to get in to charge it. The local (Tulsa) Chevy dealer wanted to tow it to his shop to fix it. (Whaaaat???)
Thanks to this forum I learned about the secret door-opening rip cord and the secret trunk opening key slot. Did I mention that the owner's manual was locked in the car? :-)
Anyway, I got it charged so now I can sell it. Too bad, a nearly new (600 mi) Corvette, but dad is gone and I can't afford to keep it. So, thanks guys! My dad can RIP. -Dion
