Replacing Heads, DIY ?
Old Aug 31, 2006 | 11:55 AM
baf2000_1's Avatar
baf2000_1
Default Replacing Heads, DIY ?
Can the driver side head be removed with the Alternator bracket installed attached?
Old Aug 31, 2006 | 12:34 PM
AintQik's Avatar
AintQik
Just take it off. Remove the water pump first and it's not bad if you have a set of ratcheting wrenches. I've done this a bunch of times and I can't remember if one of the bracket bolts goes into the block. Either way, just take it off and get it out of your way. When you go to put the head back on you dont want that thing hangin off the front to jam you up.
Old Aug 31, 2006 | 01:03 PM
baf2000_1's Avatar
baf2000_1
It looks like the Alternator and Power steering pump share the bracket. Are you saying the water pump needs to be removed too?
Old Aug 31, 2006 | 01:26 PM
CYA-Vett's Avatar
CYA-Vett
Its not explainable until you get to that one bolt. It will come off with the water pump on, but you can only turn it about 1/8 of a turn at a time. With the water pump off, you can turn it about 1/4 at a time.
Either way, yes the alternator bracket will have to come off. Changing heads sucks.
Old Aug 31, 2006 | 01:54 PM
baf2000_1's Avatar
baf2000_1
At least the passenger side looks easy...
Old Aug 31, 2006 | 01:56 PM
CYA-Vett's Avatar
CYA-Vett
Neither side is hard, it just a pain in the ***. Scraping off the old gaskets and cleaning out the bolt holes takes a while and you must do them perfectly, too tedious for me. I rather do a cam swap even though it takes a while longer.
Old Aug 31, 2006 | 02:15 PM
baf2000_1's Avatar
baf2000_1
Thanks for the help . I might just bail on this one
Old Aug 31, 2006 | 02:19 PM
CYA-Vett's Avatar
CYA-Vett
Don't do that, just take your time, you'll be fine.
We'll be around if you get stuck
Old Aug 31, 2006 | 05:37 PM
baf2000_1's Avatar
baf2000_1
Seems my shop manual was not sent out. Can someone please tell me the torque specs for the LS2 and the torque sequence both off and on .
Old Aug 31, 2006 | 05:44 PM
timd38's Avatar
timd38
You can use my shop manula if you live near Detroit. Just send me a PM.
Old Aug 31, 2006 | 06:06 PM
baf2000_1's Avatar
baf2000_1
Thanks but I am in NJ. I did find a Gen three torque sequence that is more more degrees of rotation vs torque. This will be interesting!
Old Aug 31, 2006 | 06:37 PM
AintQik's Avatar
AintQik
You are in Jersey! Jeeze man why didn't you say so. I can help you with a swap. Where are you? By the way don't use the GM bolts again. Spring for ARPs.
Old Aug 31, 2006 | 09:56 PM
CYA-Vett's Avatar
CYA-Vett
Get the lube too...
Old Sep 3, 2006 | 01:07 AM
baf2000_1's Avatar
baf2000_1
To late I got the original GM bolts. Can someone help with the torque sequence? Shop manual owners, please help...
Old Sep 3, 2006 | 04:03 AM
SpinMonster's Avatar
SpinMonster
The trick with the stock bolts is to draw a line from the center of the head of the bolt to the top edge of the bolt like a clock at 12 oclock and turnt the number of degrees they are speced for.
If Aintqik is comming then so am I to check all his mistakes and next week is out since we have to do my clutch slave cylinder first.
Old Sep 3, 2006 | 07:11 AM
baf2000_1's Avatar
baf2000_1
Ok, sound strait forward. What degrees should they be turned? Anyone ?
Old Sep 3, 2006 | 08:47 AM
AintQik's Avatar
AintQik
My mistakes? Who put your slave back on? LOL!!!! You know I'm the best dang wrench you know... betta recognize
Old Sep 3, 2006 | 09:02 AM
CYA-Vett's Avatar
CYA-Vett
Check about half way down this article
Old Sep 5, 2006 | 09:57 AM
baf2000_1's Avatar
baf2000_1
That was what I needed. So I took the heads off, did a port and polish. Put her back together and all is running great !!
What has changed:
- DIY Port and polish. I have done this before on other cars.
- SLP 1.85 rockers, springs & retainers.
- Dynotech 1-7/8 headers and cats.
- Vararam
- HPTuners DIY narrow band O2 tune
The car simply flies!! I would say she has 50-80 more HP. I did have a scare when she started to run rough after a few min. But it turned out to be a loose spark plug wire!
Thanks to all with the quick replies!!
To Replacing Heads, DIY ?
