How to keep Vararam connected?
Old Sep 3, 2006 | 11:45 PM
SoldSyclone's Avatar
SoldSyclone
Default How to keep Vararam connected?
The front connection on the upper potion of my vararam keeps poping off any tips to keep it connected?
Old Sep 4, 2006 | 05:23 AM
Blue02Z06's Avatar
Blue02Z06
I have the exact same problem. Its almost like they cut the silicone coupler about an inch too short. I just give it a little room on the MAS side so some metal shows and its been holding tight ever since. Just make sure its as snug as possible and you have the coupler as far down on the plastic shroud as possible.
best of luck
Dave
Old Sep 4, 2006 | 05:29 AM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Buy the LPE or Callaway CAI and don't worry about it.
Old Sep 4, 2006 | 08:01 AM
yell03's Avatar
yell03
Couldn't you just run over to Home Depot or Lowes and buy a slightly longer coupler???
That is what I would do, otherwise I'd be worrying that it would pop off everytime I drove.
Howard
Old Sep 4, 2006 | 08:04 AM
connor's Avatar
connor
Not a problem here and its been on for awhile. Have you called their customer service?
Old Sep 4, 2006 | 09:43 AM
dennis50nj's Avatar
dennis50nj
no problem hear due you have the spacer
Old Sep 4, 2006 | 11:05 AM
06corvette's Avatar
06corvette
I have no problem with it. and i'm going to install the spacer tommoro
Old Sep 4, 2006 | 11:27 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
You hear about more problems associated with the build quality of the Vararam here than any other CAI system.
If there is going to be a build quality, or fitment issue discussed about someone's CAI, its almost always the Vararam and virtually never the Callaway or the Lingenfelter.
Old Sep 4, 2006 | 05:22 PM
dennis50nj's Avatar
dennis50nj
i have never had a problem, one of the first ones. i installed it. must have done it right i can remove filter to check and it doesnt come off. and it is still faster than the others.
Old Sep 4, 2006 | 06:08 PM
Z06 Steve's Avatar
Z06 Steve
I agree my C5 vararam was built by a 6th grader and the foam filter a pre k
Old Sep 4, 2006 | 06:15 PM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
Lousy instructions and fit cost me a condenser!
Old Sep 4, 2006 | 06:50 PM
tluck's Avatar
tluck
Vararam will replace the original rubber connector with a 2" at no charge.
Old Sep 4, 2006 | 07:48 PM
Blue02Z06's Avatar
Blue02Z06
if you dont mind me asking, how do you go about having this done?
Dave
Old Sep 4, 2006 | 08:55 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Dennis,
It's nut behind the wheel and not the nut under the hood
Old Sep 4, 2006 | 09:00 PM
dennis50nj's Avatar
dennis50nj
Originally Posted by Tommy D
Dennis,
Old Sep 5, 2006 | 09:10 AM
tluck's Avatar
tluck
Here's what I did. Call Vararam, tell them the problem, and they'll send you the 2" rubber connector @ no charge.
Old Sep 5, 2006 | 12:56 PM
tjd113's Avatar
tjd113
I also have the same problem and yes the rubber coupler is to small
To How to keep Vararam connected?
Old Sep 5, 2006 | 09:59 PM
JLinCA's Avatar
JLinCA
My guess is that you do not have the spacer? With the spacer installed the neck of the VR attaches directly to the MAF and is clamped. Of course the instructions show a coupler being needed, so until I figured it out I was going around thinking I was missing a part.
Old Sep 14, 2006 | 06:36 PM
SoldSyclone
I do have the spacer, I will shoot a pic of the b4 and after.
VR sent me the new part looks much better IMO
Old Sep 16, 2006 | 04:57 PM
C6 Vette's Avatar
C6 Vette
Default Need help getting VaraRam Installed.....
They sent me a bigger section of the material and that helped. I suspect they will do whatever you want, based upon my experience with them. Now, I need some help myself with the installation.
I have had problems too. I bought my unit in March and it did not fit well. The top peice did not overlap enough with the filter installed to provide a safe overlap and complete seal. I complained to VaraRam and they were very quick to help me. It turns out they were redesigning the product to make that correction, along with a couple of other changes. I was very impressed that they were doing this, and did so very quickly.
Any company willing to jump through that much deserves my patience and I am willing to keep trying. Now I am having more problems. By the way, the reason I have delayed installing it was due to recalls and two replacements of my Heat/AC unit. It keeps blowing hot air when the AC is on! The car has been at the dealer for over 3 weeks this summer! And the fuel pump issue is still not fixed, I didn't want to leave it another week for that problem too!
Now I am trying to install the new product and I cannot get it to line up properly. I have tried everything I know to make it work. I suspect I am doing something wrong, but I cannot figure it out.
It's installed in my Corvette and it doesn't line up right. The intake is about 3" to 4" to high and the hood won't even close. I even tried flipping over the bar that attaches the lower section to the Corvette and that didn't work. I enlarged the opening too, but that didn't work. I am now wondering if the cutout has to be flush at the bottom??? My instructions were not that good, and I used the template they sent me, it was far from accurate and I have enlarged it three times!
Any ideas out there? Anyone with good pictures I could see?
Thanks!
