Wrapped Headers???
Old Sep 12, 2006 | 04:07 PM
boosted_z06's Avatar
boosted_z06
The biggest performance benefit of coated headers is that they help keep the heat in the exhaust system. As the exhaust gases cool, they also lose velocity.
By keeping the exhaust hot, the velocity will be higher and you will get more of a scavenging effect. At low rpm, reverse flow will be reduced also. By keeping the heat in the exhaust system, you also reduce under hood temperatures, which can really be a plus if your aircleaner is breathing under hood air.
Thermal wrap does a better job at insulating heat and reducing under hood temperatures, but they also tend to hold in moisture and cause rust.
If you use wrap on a street car, you should use a coated header to help it last. Headers will not last as long if they are run hotter, and wraps make the header run much hotter. The metal will fatigue much quicker. Gaskets will also fail sooner if the system is hotter, especially the collector gaskets.
Depending on what the header is made of coating or wrapping will cause welds to crack or cause like stainless steel to change shape.
Coatng CAT is stupid for the hotter they get the more excess fuel the PCM commands to cool the CAT off.
Changing the internal exhaust temp will effect the O2s and cause PCM to make AFR canges when it really was not needed so tuning the PCM is a must.
Old Sep 12, 2006 | 04:44 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
My mileage has improved, so I'm not sure what you mean. Cat's are suppose to run hot.
Old Sep 13, 2006 | 10:49 AM
boosted_z06
No they are supposed to operate over a set temp range and when they get over that temp the PCM kicks in COT ( Cat OverTemp) which dumps fuel in to cool the Cat and why people call when at WOT being pig rich.
The PCM is assuming what the CAT temp is only by what the O2s report so coating exhaust also then reflects what the O2s report.
Old Sep 13, 2006 | 01:42 PM
TommyV's Avatar
TommyV
My AF's were right on during my last dyno, so I'm not too concerned.
Old Sep 14, 2006 | 06:30 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
does that occur at a specific temp. or does it occur when the front and rear o2 sensor temps/readings are too close to each other.
Old Nov 16, 2006 | 01:16 PM
heavychevy's Avatar
heavychevy
Sorry to go digging but I have heard that wrapping on top of coating is not good because it causes the coating to crack. Does anyone else have an opinion on this.
Old Nov 16, 2006 | 01:59 PM
RDunn's Avatar
RDunn
a big +1 for jethot
Old Nov 16, 2006 | 02:16 PM
TTRotary's Avatar
TTRotary
This is not correct. I think you are thinking of the use of excess fuel to provide in-cylinder cooling on turbo cars, which is why you run turbo cars rich at WOT. If you add fuel to a converter, you are increasing the chemical inputs, which will result in more heat. Think about it. Empirically, excess fuel is the reason FI cars often burn out their cats.
In fact, hotter exhaust temps actually LOWER the operating temps inside the catalyst because there are fewer hydrocarbons to be processed.
Old Nov 17, 2006 | 12:53 AM
runutzzzzz's Avatar
runutzzzzz
What about wrapping a jet-hot pipe? Is it no needed?
