The two cams will have a very similar TQ curve. The 112 cam will have a slightly better mid-range, will fall off a little more quickly after the peak HP point. The 114 cam will have a better idle and off-idle throttle response, peak TQ will not be quite as high, power will not die off quite as quickly after peak HP is reached.
The difference between the two cams is almost negible. Main difference is the lope at idle. On a larger cam, the 112 grind might have a bit more difficulty passing an emissions test.
