kooks headers which gaskets?
Old Sep 26, 2006 | 12:27 PM
Z06 Steve's Avatar
Z06 Steve
Default kooks headers which gaskets?
will the factory stock C6 GM exhaust manifold gaskets work ? the fiber ones supplied not too shure about them lasting.
Old Sep 26, 2006 | 01:28 PM
CYA-Vett's Avatar
CYA-Vett
Either is fine, most just reuse the stockers....
Old Sep 26, 2006 | 02:11 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I bought new GM gaskets. They are the best to prevent leaks. They only cost $20, cheap insurance.
Old Sep 26, 2006 | 02:34 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
i wouldn't reuse the stock ones, once they get compressed they are useless.
the one's that came with my kook's headers seem to be ok. if you're worried about it, and it will give you piece of mind, run over to gm goodwrench and pick up a new pair.
Old Sep 26, 2006 | 04:40 PM
andreas g.'s Avatar
andreas g.
Use the GM factory steel round gaskets. They never leak or need retorquing
Old Sep 26, 2006 | 05:19 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Buy new gaskets from gm $20
It will be money wll spent !
Old Sep 26, 2006 | 05:34 PM
Z06 Steve's Avatar
Z06 Steve
are the rear o2 extentions needed I was told with the kooks the stockers would reach?
Old Sep 26, 2006 | 06:44 PM
burtonbl103
kooks kit comes with the extenders !
Old Sep 26, 2006 | 06:50 PM
Zig's Avatar
Zig
ain't no way the stock cables will reach. i've spent the last few days under my car installing a pure custom exhaust, using kooks headers and high flow cats. the extensions reach with just enough length to route them away from the pipes.
Old Sep 26, 2006 | 07:11 PM
Z06 Steve's Avatar
Z06 Steve
thanks did you use 24" in the rear o2's i'm collecting some missing items for a used set.
To kooks headers which gaskets?
