Lowering C6
Old Sep 27, 2006 | 07:43 AM
corracer's Avatar
corracer
Default Lowering C6
im planing on lowering my 06 , i did my 99 and had shock issues, what needs to be done on 06 , and how much can it be lowered safely thnx VINCE
Old Sep 27, 2006 | 11:32 AM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
Shock issues? You mean bottoming out?
You can lower both ends just like the front end on a C5. Stock bolts to lower a little, aftermarket bolts or bushings to go even lower. How low safe is depends on where/how you drive and your idea of safe. Mine's on Zip's bushings and I've never scraped anything except the air dam. But there's plenty of members that have had problems at this height.
Old Sep 28, 2006 | 01:00 PM
platinumkid's Avatar
platinumkid
i lowered mine by cutting the rubber bushing in half!! took 20 minutes and came out beautiful!! and it still rides the same, just gotta be more carefull with how you drive. that front bumber's very low to the ground! you wanna make sure to take care of that!!
Old Sep 28, 2006 | 03:42 PM
emejay's Avatar
emejay
Can the rear rubber bushing be cut without removing all the suspension parts? What is the best way to do that? I was thinking of using a hack saw blade, but would love to hear from someone who has actually done it.
Old Sep 28, 2006 | 04:21 PM
platinumkid
yea, what i did was jack up one side and cut the bushing with a hack saw!!! it took 20 minutes and it came out amazing!! you dont even need to remove the rim! just jack it up and cut it from underneath!
Old Sep 28, 2006 | 06:00 PM
Gundam's Avatar
Gundam
Can a sawzall be used? Is there enough room to safely do it?
Old Sep 28, 2006 | 06:16 PM
AintQik's Avatar
AintQik
I removed the bolt and used a sawzall
Old Sep 28, 2006 | 08:47 PM
timd38's Avatar
timd38
I would love to lower mine, but I can't get up my driveway now!
Old Sep 28, 2006 | 09:10 PM
2008corvette's Avatar
2008corvette
Here's my lowered C6
Old Sep 28, 2006 | 11:00 PM
PeteServMgr's Avatar
PeteServMgr
Default Lowering
Sawsall works .. .get a long blade .. don't use real fine teeth as it will cut too slow and create a lot of smoke... liquid soap helps as a lubricant.
I only cut my rears ... the front lowered enough with a wrench.
Good luck.
Old Sep 29, 2006 | 02:30 PM
c6power's Avatar
c6power
I lowered my car last week and I love it. I purchased my kit from zip.com $25. My profile has a pic lowered.
To Lowering C6
