Nitrous bottle valve
Old Sep 27, 2006 | 09:45 AM
wratran's Avatar
wratran
Default Nitrous bottle valve
Does anyone know how to remove the main valve on the nitrous bottle? I dont see any nut and treads fitting on it. It seem like the valve assembly is tightly fit to the bottle collar.
I have to rotate the valve so my nitrous outlet is parrallel to the floor. My remote bottle opener is so tight to the floor is the outlet is pointing down. I have the HSW kit. They told me if i have to rotate the bottle, the siphon tube have to be adjusted....is this true?
Old Sep 27, 2006 | 04:02 PM
patton's Avatar
patton
St. Jude Donor '09
is the bottle full ? if not remove the whole assembly from bottle mine used an o ring then some how mark assembly where the tube faces so when ya screw it together the mark will show the lowest point of the tube . i mounted mine side ways on an angle behind driver seat so i could get at it while driving. i dont trust elect bottle opener. youre instructions should make it VERY CLEAR about pickup tube
