Need help with E-Fans
The reason I ask is that in HPTuners the newer Vette's (2005 and up) use Pulse Width Modulation (PWM) in the fan tables where as the older Vettes and even the current GTO uses a discreet (on/off) syle. This makes me think that the PCM is sending some sort of variable signal to the fans instead of a simple on/off command, which would have to be done through a specialized relay or controller since the PCM obviously could not controll the fans directly with out melting down.
If no one has a wiring diagram of the fans, does anyone have the pinout map for the PCM? Thanks for the help
would it be possible to disconnect the fan controller and connect your own. will the ecm freak out or care less about the open circuit ?
We make and sell a fan controller module for the C6s. it's fully adjustable from 160 on up and wont set the SES light.
You can also send the ECM to us and we can reduce the fan temps that way, but the drawback with doing it with a re-tune is that the software won't allow fan temps below 192.
Julio
Julio
Thanks for the input. Is this controller that you sell driven by the PCM, or does it use a seperate temp sensor along with an A/C sensor? After doing some more research it does not appear that I can set the stock PCM to control the fans below 192* anyways due to GM's new logic for the fan control. Can you shoot me a price on your setup? Thanks
There are two ways to lower the fan temps below 192 in the tuning software, (1) with a custom operating system for boosted cars 2.5 bar, so if you are not running boost it's not recommended (2) You can rescale all the coolant tables, but your dashboard won't display the correct temps anymore.
Julio
