An H Pipe is GM's cheap way to try and balance Exhaust pulses. An X pipe has showed time and time again to work much better. what this means is as exhaust gases travel through there respective pipes there velocity begins to slow. By connecting the two pipes the alternating pulses help maintain some velocity there by helping to scavenge the cylinders more effectively which aids in the filling of the cylinders with the incomming fuel and air charge. In theory this increases torque somewhat. It also lessens the poping you sometimes here during
deceleration. Also the x pipe works better because exhaust gases don't like to make 90 degree turns, and the X pipe is the same diameter as the exhaust pipes where as the H pipe connector is smaller in diameter.
As for your statement about keeping HP down it's miminal. Meaning it's not a major restriction. If you're going to leave your car stock then leave the H pipe alone.
"H" pipes with aftermarket exhaust gives the car a nice gurgle sound when you let off the gas or downshift, I heard that when you replace it with an "X" pipe it eliminates that sound. I have Bullets and am getting American Racing headers with a X-pipe and high-flow cats, I will miss that cool gurgle/popping sound.
[QUOTE=andreas g.] Also the x pipe works better because exhaust gases don't like to make 90 degree turns, and the X pipe is the same diameter as the exhaust pipes where as the H pipe connector is smaller in diameter.QUOTE]
I thought that was on the C5 exhaust system. Didn't GM redesign the C6 H pipe connection to be the same diameter as the exhaust pipes, or did they keep the same small tube design? Just wondering...
