who really knows
Old Oct 5, 2006 | 11:32 PM
dennis50nj's Avatar
dennis50nj
Default who really knows
who knows what happens when you air your drag tires slicks down under 23 lbs and warning light on i tried reset button nothing will it put you in limp mode
Old Oct 5, 2006 | 11:43 PM
Ranger's Avatar
Ranger
Why put TPS in drag radials?
I have none in mine and have driven 200 miles and 10 passes straight, with no issue. At about 30 miles, a DIC message appears stating Service Tire Monitor System. I just clear it. No issue.
Ranger
Old Oct 6, 2006 | 12:05 AM
dennis50nj's Avatar
dennis50nj
Ranger
thanks Ranger but i was going to leave them on bfgs with sensors and was wondering what happens when i air them to 16 lbs. will it slow me or is their a way around it . i heard the canister but the tire spinning activates out of sleep mode. and was told sleep mode works to a point but after so many cycles you start having problems any other advise
Old Oct 6, 2006 | 01:41 AM
LS1LT1's Avatar
LS1LT1
The beauty of drag radials is that you shouldn't ever really have to run them at 16psi, or even anything under 22psi for that matter...of course at 22 or even 24 it might still set off the DIC if ya have the fronts pumped up.
Old Oct 6, 2006 | 02:34 AM
shurite44's Avatar
shurite44
If you have less than ten pounds of pressure it is considered a flat tire. You will get a flat tire message, then a 55 max speed message, a reduced handling message and active handling will become more sensitive.
If you have less than 24 but more than ten you will get a low tire pressure DIC message. I think all that happens for a low pressure condition is the message.
As far as no sensors, I do not know. Ranger has done it as he states above with no problems. Maybe the computer does not view this as a flat.
Dennis check this info in the manual. I am going from memory here so I may be a little off on the details.
Old Oct 6, 2006 | 03:06 AM
shurite44's Avatar
shurite44
Also Dennis if you have a flat tire situation you will be confined to active handling on, if you have it off it will turn on by itself.
Old Oct 6, 2006 | 03:23 AM
shurite44's Avatar
shurite44
I re read Ranger's post. If the DIC is saying service TPS instead of flat tire I would say it differentiates between a missing sensor and a flat tire.
Old Oct 6, 2006 | 07:02 AM
yell03's Avatar
yell03
I am so worried about the Computer cutting power, I don't let my fronts ever read higher than 36# on the DIC (I have received an overinflation warning at around 40#) or my rears drop below 26# (I have received a low pressure warning around 24-25#).
Am I being paranoid?
Probably, but if I can get down the track with hot tire pressures of 27-28# rears and 35-36# fronts I won't complain.
I am sure I would run a bit better with 25-26# rear hot and 37-38# front hot, but my luck, after a lengthy cooldown in the lanes, I would get a warning at the line and it would pull timing or at least throw me off by thinking about it.
Howard
Old Oct 6, 2006 | 08:51 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
good question.
i can't answer your question directly, but i can say this.
i just finished installing my headers. it took a bit longer than i wanted, but all-in-all, it wasn't bad, and i got to do all the work myself, save for a little welding. well, anyhow, i had disconnected the battery when i started and reconnected it when i finished. i normally drive in 'comp' mode but for some reason all it would allow was 'traction control on','traction control off'. no, 'comp mode' and no 'all off'. i stopped and started her but still, no 'comp. mode'. finally, it dawned on me. check the pressure reported by my DIC (hehehe, that is just too funny, infintile, but funny). Hey, look, my tires are flat. 0lbs, in each tire. dag-nab it. oh, well. i waited it out, let the system get a reading for each tire and wha-lah, 'comp' mode, 'all-off' mode, everything back to normal.
granted i have an '05 mn6 f55, but that's how it worked with mine.
Old Oct 6, 2006 | 01:07 PM
BEZ06's Avatar
BEZ06
with everything most people have been saying - if you get a DIC alert message just clear it.
Like Ranger said, even if you don't have sensors, when you start driving the TPMS is looking for a report from the sensors and it takes the car "about 60 minutes" (according to the manual) of steady driving before it decides the sensors aren't going to check in and the DIC will then give an alert "Service Tire Monitor" and maybe followed by "Limit Speed to 55".
That message is the so-called "limp mode" but my experience has been that it is just a message and there is nothing that electronically or mechanically limits your speed - you can go as fast as before.
You may not be able to turn off Active Handling or go into Comp mode, but you will still be able to turn of Traction Control. Like Ranger says, you should be runnin' the strip with AH on anyway. If you're road racing you probably want to be able to turn it off, but you're still not gonna have a problem unless you're doing sessions more than "about 60 minutes" long.
If you drop your pressures down and the DIC sends a message, you should be able to clear it and have no problems at the drag strip.
Bob
RLTW
Old Oct 6, 2006 | 01:19 PM
LS1LT1's Avatar
LS1LT1
Not paranoid, I had the same fears after I read it here or had someone tell me about that possibility (it may have been you telling me at the track LOL ) but your fears may not be entirely valid either. I would like to experiment with this front to back pressure variation/gap and see if it can just be cleared or if it will in fact reduce power because I'm a firm believer in pumping up the front tires (and lowering the backs a little of course) for reduced rolling resistance at the track.
Old Oct 6, 2006 | 04:14 PM
dennis50nj's Avatar
dennis50nj
i always run with tire presure rear at 24lbs hot so each day when i pull car out of garage they are low you can not reset low tire in dash and right and left tire lbs presures in dic can not be reset it keeps flashing in the dic and on in the dash gauge and goes out when presure reaches 24lbs. with in a mile or so. but what is long term problems
Old Oct 6, 2006 | 05:12 PM
boosted_z06's Avatar
boosted_z06
Ranger
Ooh there is a issue for every time you clear any code you also force the ECM to clear ALL EPA smog tests back to non complete state and force the ECM to have to spend clock time doing all those tests again till they are in a "passed" complete state and less clock time to do its real time work.
EPA forces all their tests reset back to fail state any time errors are deleted or erased.
To who really knows
