Brake and clutch fluid ??
Old Oct 12, 2006 | 05:10 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Default Brake and clutch fluid ??
What is everyone using ?
I am going to purge my brake fluid when i winterize my c6 in a few weeks and well as turkey baste, and pump flush the clutch fluid
What should i use ?
Old Oct 12, 2006 | 05:25 PM
Miaugi's Avatar
Miaugi
As you probably know the clutch requires minimum DOT 4 and the brakes requires a DOT 3. There are several goods brands available of both, but just like motor oil everyone has their own preference. Myself I am using a DOT 5.1 AP Racing fluid in both my clutch and brakes and I am staisfied with the perfromance of that brand. Just do not use a DOT 5 in either system.
Old Oct 12, 2006 | 05:47 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
I've been using ATE superblue.
Old Oct 12, 2006 | 06:23 PM
burtonbl103
How did you completely purge the clutch
Or did you do the turkey baster and pup 13 times method?
Old Oct 12, 2006 | 06:35 PM
Miaugi's Avatar
Miaugi
As a rule, every 3 or 4 weeks when I'm under the hood I just suck out the old (with a siphon pump) then refill with the new, the whole process takes 2 - 3 minutes including clean up. Just be careful not to ever get brake fluid on the paint, I'm told it's very corrosive.
Old Oct 12, 2006 | 07:09 PM
burtonbl103
Can you use the superblue in the clutch as well ?
Old Oct 12, 2006 | 07:25 PM
mlongo99's Avatar
mlongo99
I assume so. I see no reason to not run any brand of hydrolic fluid in both the brake and clutch system, as long at it meets the spec for both. DOT4 requires a minimum wet boiling point of about 312deg. ATE's wet boiling point is 398deg. When I flush my clutch fluid, that's what I will be using.
BTW, ATE makes 2 types: blue and gold. The only difference is color, that way it is easy to tell when you're done flushing the old stuff out. Since the clutch fluid gets dark when it gets contaminated, it would probably be better to use the gold, since it is much lighter.
Old Oct 12, 2006 | 07:45 PM
burtonbl103
Just bought this
http://cgi.ebay.com/ebaymotors/ws/eB...4502494&rd=1,1
To Brake and clutch fluid ??
